Swamee-Jain Friction Factor Equation and Calculator
This is another explicit equation for calculating the friction factor typically used in the Darcy-Weisbach. It was first presented by P. K. Swamee and A. K. Jain in 1976 in the Journal of the Hydraulics Division of ASCE. This equation is the easiest of all explicit equations for calculating the friction factor.
The Swamee-Jain equation is expressed as
Equation 1
f = 0.25 / [ log10 ( ε / 3.7 d + 5.74 / Re0.9 ) ]2
f = friction factor, (dimensionless)
ε = absolute pipe roughness, (in, mm) depends on the condition of the pipe.
It ranges from 0.001 to 0.01.
d = inside diameter of pipe, (in, mm)
Re = Reyonds number, (dimensionless)
- Liquid Pressure Drop in Pipe and Pipe Fittings Spreadsheet Calculator
- Friction Loss - Fluid Flow Hydraulic and Pneumatic
- Darci's Equation Fluids Flow Equation
- Pipe Flow/Friction Factor Calculations with Excel Training - 3 PDH
- Unwin Gas Change of Pressure Calculator and Formulas
- Gas Flow Rate Through Orifice Equations and Calculator per. ISO 5167
- Natural Gas Pipe Flow Rate Calculator
- Appliance Gas Pipe Flow Rate Capacities
- Transmission Gas Line Isothermal Flow Equations and Calculator
- Fluids Discharge Measurement Structures and Systems , Basic Principles of Fluid Flow as Applied to Measuring Systems
- Hydraulic and Pneumatic Design and Engineering
- Piping Calculations Manual,
E. Shashi Menon
SYSTEK Technologies, Inc
