Torque Rating Synchronous Timing Belt Equation and Calculator
Synchronous Timing Belt Torque Rating Equation and Calculator per. ANSI RMA IP-24, ISO 5299 and IS 9804 for small pitch MXL section belts
Use horsepower rating design formulas for synchronous belts, other than the MLX sections:
Synchronous Timing Belt Horsepower Rating Equation and Calculator per. ANSI RMA IP-24
Qr = Kz [ d ( 1.13 - 1.38 x 10-3 d2) ] For belt width = 0.12 in.
Qr = Kz [ d ( 1.88 - 2.30 x 10-3 d2) ] For belt width = 0.19 in.
Qr = Kz [ d ( 2.63 - 3.21 x 10-3 d2) ] For belt width = 0.25 in.
Qr = maximum torque rating (lbf-in.) for a belt of specified width having six or more teeth in mesh and a pulley surface speed of 6500 fpm or less.
Kz = Torque rating multiplier (see Table Below). Torque ratings for drives with less than six teeth in mesh must be corrected as shown.
d = pitch diameter of smaller pulley in belt mechanism, inch.
Teeth in Mesh (N)
Factor Kz
6 or more
1.00
5
0.80
4
0.60
3
0.40
2
0.20
- Synchronous Timing Belt Tooth Section Dimensions Table per ANSI / RMA IP-24
- Synchronous Timing Belt Pulley Dimensions Table per ANSI / RMA IP-24
- Synchronous Timing Belt Lengths and Tolerances per. ANSI RMA IP-24 Table
- Service Factors Synchronous Timing Belts
- Synchronous Timing Belt Standard Widths and Tolerances Table
- Synchronous Belt Standard Pulley Diameters ANSI/RMA IP-24 Table
- Timing Belt Pulley Mechanical Tolerances per. ANSI RMA IP-24
ANSI / RMA IP-24
ISO 5299
IS 9804.
