Work Holding Toggle Mechanism Calculations
Work Holding Clamping Toggle Mechanisms Calculations
Basic lever arm clamp design with forces applied and reaction forces calculator.
Preview: Work Holding Clamping Toggle Mechanisms Calculator
Q = P [ ( l + r · fo ) / ( l1 - r · fo ) ]
P = Q / [ ( l + r · fo ) / ( l1 - r · fo ) ]
Figure 1
Q = force applied to handle. lbf, (N)
P = clamping force, lbf. (N)
fo = coefficient of friction (axles and pivot pins) = 0.1 to 0.15
l, l1 = length as indicated. in, (mm)
r = radius of pivot hole. in, (mm)
Handbook of Machining and Metalworking Calculations
Ron A. Walsh
2001
- Toggle Clamp Equations and Calculator
- Toggle Clamps Animation
- Mechanisms in Modern Engineering Design
- Theory of Mechanisms and Machines
- Ingenious Mechanisms Volume I for Designers and Inventors
- Ingenious Mechanisms Volume II for Designers and Inventors
- Simple Mechanical Levers Equations and Calculators
- Adding Forces by the Parallelogram Resultant of Two Forces Equation and Calculator
- Geneva Mechanism External Design Calculator and Equations
