Related Resources: fluid flow
Flow Losses for Valves and Fittings
Fluid Flow Table of Contents
Flow Losses for Valves and Fittings in Equivalent Feet if Pipe. Losses are assumed with device in full open position.
Nominal |
Valve and Fitting Fluid Flow Losses Data Given in Equivalents of Feet of Pipe
Globe |
60º
Y Valve |
45º
Y Valve |
Angle
Valve |
Gate
Valve |
Swing
Check Valve |
Y
Strainer |
90º
Elbow |
45º
Elbow |
Flow-Thru
Branch |
1/2
18
9
7
7
0.7
6
3
1.6
0.8
3
3/4
22
11
9
9
0.9
8
4
2
0.9
4
1
29
15
12
12
1
10
5
2.6
1.3
5
1 1/4
38
20
15
15
1.5
14
9
3.3
1.7
7
1 1/2
43
24
18
18
1.8
16
10
4
2.1
8
2
55
30
24
24
2.3
20
27
5
2.6
10
2 1/2
69
35
29
29
2.8
25
28
6
3.2
12
3
84
43
35
35
3.2
30
42
7.5
4
15
3 1/2
100
50
41
41
4
35
48
9
4.7
18
4
120
58
47
47
4.5
40
60
10
5.2
21
5
140
71
58
58
6
50
80
13
6.5
25
6
170
88
70
70
7
60
110
16
7.9
30
8
220
115
85
85
9
80
150
20
10
40
10
280
145
105
105
12
100
190
25
13
50
12
320
165
130
130
13
120
250
30
16
60
14
360
185
155
155
15
135
34
18
68
16
410
210
180
180
17
150
38
20
78
18
460
240
200
200
19
165
42
23
85
20
520
275
235
235
22
200
50
26
100
24
610
320
265
265
25
240
60
30
115
Reference: Carrier Binder, Chapter 3 Piping Design
Nominal
Pipe Size (mm) |
Valve and Fitting Fluid Flow Losses Data Given in Equivalents of Meters of Pipe
Globe
Valve |
60 º
-Y Valve |
45º
Y Valve |
Angle
Valve |
Gate
Valve |
Swing
Check Valve |
Y
-Strainer |
90 º
Elbow |
45 º
Elbow |
Flow-Thru
Branch |
15
5.5
2.7
2.1
2.1
0.2
1.8
0.9
0.5
0.2
0.9
20
6.7
3.4
2.7
2.7
0.3
2.4
1.2
0.6
0.3
1.2
25
8.8
4.6
3.7
3.7
0.3
3.0
1.5
0.8
0.4
1.5
32
11.6
6.1
4.6
4.6
0.5
4.3
2.7
1.0
0.5
2.1
40
13.1
7.3
5.5
5.5
0.5
4.9
3.0
1.2
0.6
2.4
50
16.8
9.1
7.3
7.3
0.7
6.1
8.2
1.5
0.8
3.0
65
21.0
10.7
8.8
8.8
0.9
7.6
8.5
1.8
1.0
3.7
80
25.6
13.1
10.7
10.7
1.0
9.1
12.8
2.3
1.2
4.6
90
30.5
15.2
12.5
12.5
1.2
10.7
14.6
2.7
1.4
5.5
100
36.6
17.7
14.3
14.3
1.4
12.2
18.3
3.0
1.6
6.4
125
42.7
21.6
17.7
17.7
1.8
15.2
24.4
4.0
2.0
7.6
150
51.8
26.8
21.3
21.3
2.1
18.3
33.5
4.9
2.4
9.1
200
67.1
35.1
25.9
25.9
2.7
24.4
45.7
6.1
3.0
12.2
250
85.4
44.2
32.0
32.0
3.7
30.5
57.9
7.6
4.0
15.2
300
97.6
50.3
39.6
39.6
4.0
36.6
76.2
9.1
4.9
18.3
350
109.8
56.4
47.3
47.3
4.6
41.2
10.4
5.5
20.7
400
125.0
64.0
54.9
54.9
5.2
45.7
11.6
6.1
23.8
450
140.2
73.2
61.0
61.0
5.8
50.3
12.8
7.0
25.9
500
158.5
83.8
71.6
71.6
6.7
61.0
15.2
7.9
30.5
600
186.0
97.6
80.8
80.8
7.6
73.2
18.3
9.1
35.1
Related Resources:
