Compression Tension Stress Linear Thermal Expansion Equation and Calculator
Heat Transfer Engineering
Thermodynamics
Compression or Tension Stress is the change in stress due to the material expansion by the change of temperature.
Stress Linear Expansion
Preview: Calculator Change of Length
Stress
σ = E α ΔT
or
σ = E ε
ΔT = End Temperature T1 - Start Temperature T2 (°F, °C)
E = Youngs Modulus (psi, N/m2)
α = Coefficient of Thermal Expansion (1/°F, 1/°C). Note: that units may be expressed as in / in-°F, m / m-°C
ε = Strain ΔL/L ( in/in, m/m) That would have occured if linear feature no restrined axially.
