Gage Tolerance Calculator ASME B89.1.5 Pin and Ring Gauges
This calculator will determine the gage class and tolerance per ANSI ASME B89.1.5 for cylindrical I.D and O.D. gages.
Input Data
Units: =
Maximum Feature Size: =
Minimum Feature Size: =
Results
Total Feature Tolerance Variation = 0.022
Calculated Gage Tolerance = 0.0011
(10:1 rule) Suggested Gage Tolerance = 0.0002
Gage Class   ZZ
Input Data and Result are rounded to 8 decimal places.
Suggested gage tolerance is calculated using the 10% product tolerance rule.
Gage Tolerance Chart Table per. ANSI/ASME B89.1.5
Diameter Range
(Above-Including)
Gage Class
XXX
XX
X
Y
Z
ZZ
0.010" - 0.825" 0.000010" 0.000020" 0.000040" 0.000070" 0.000100" 0.00020"
0.825" - 1.510" 0.000015" 0.000030" 0.000060" 0.000090" 0.000120" 0.00024"
1.510" - 2.510" 0.000020" 0.000040" 0.000080" 0.000120" 0.000160" 0.00032"
2.510" - 4.510" 0.000025" 0.000050" 0.000100" 0.000150" 0.000200" 0.00040"
4.510" - 6.510" 0.000033" 0.000065" 0.000130" 0.000190" 0.000250" 0.00050"
6.510" - 9.010" 0.000040" 0.000080" 0.000160" 0.000240" 0.000320" 0.00064"
9.010" - 12.010" 0.000050" 0.000100" 0.000200" 0.000300" 0.000400" 0.00080"
Related Resources:
