Ring gage and Master Disc Tolerances per B89.1.5
The table defines Ring gage and Master Disc mechanical tolerances per B89.1.5-1998 (R2009) Measurement of Plain External Diameters for Use as Master Discs or Cylindrical Plug Gages
Gage Tolerance Chart ANSI/ASME B89.1.5 Inch Units
Diameter Range
XXX
XX
X
Y
Z
ZZ
.010 - .825
.000010
.000020
.000040
.000070
.0001
.0002
.825 - 1.510
.000015
.000030
.000060
.000090
.00012
.00024
1.510 - 2.510
.000020
.000040
.000080
.00012
.00016
.00032
2.510 - 4.510
.000025
.000050
.0001
.00015
.0002
.0004
4.510 - 6.510
.000033
.000065
.00013
.00019
.00025
.0005
6.510 - 9.010
.000040
.000080
.00016
.00024
.00032
.00064
9.010 - 12.010
.000050
.0001
.0002
.0003
.0004
.0008
Gage Tolerance Chart ANSI/ASME B89.1.5 Metric Units mm
Diameter Range
XXX
XX
X
Y
ZZ
.254 - 20.96
.00025 .00051
.00102
.00178
.00254
.00508
20.96 - 38.35
.00038 .00076
.00152
.00229
.00305
.00610
38.35 - 63.75
.00051 .00102
.00203
.00305
.00406
.00813
63.75 - 114.55
.00064 .00127
.00254
.00381
.00508
.01016
114.55 - 165.35
.00084 .00165
.00330
.00483
.00635
.01270
165.35 - 228.85
.00102 .00203
.00406
.00610
.00813
.01626
228.85 - 305.05
.00127 .00254
.00508
.00762
.01016
.02032
Tolerance Notes:
Cylindrical Ring Gage | Go Member is to the minus side, Nogo Member is to the plus side. |
Cylindrical Plug Gage | Go Member is to the plus side, Nogo Member is to the minus side. |
Master Gages | Tolerance is split 50/50 or Bi lateral Equal |
Related Resources:
- Gauge Blocks Tolerances Specifications Table JIS B 7506
- Gauge Blocks Tolerances Specifications Table BS 4311
- Dowel Pin Installation Design Tolerance Table Chart
- Gage Tolerance Calculator ASME B89.1.5 Pin and Ring Gauges
- GD&T Geometric Dimensioning Tolerancing Basics Training
- GD&T Geometric Dimensioning Tolerancing Intermediate Training
- GDT ASME Y14.5-2009 Applications Training
- G&T Geometric Tolerancing ISO 1101 Training
- Online GD&T Fundamentals Training
