Related Resources: pumps
Eductor Pump Design Equations
Pump Types | Pump Applications Pump Design Equations
General Purpose Eductor have a capacity (flow rate) for a general purpose eductor used for pumping and blending. This type of eductor, has a broad performance span rather than a high peak efficiency point. Standard construction materials for this type of eductor are cast iron, bronze, stainless steel, and PVC. Typical uses include cesspool pumping, deep-well pumping, bilge pumping aboard ship, and condensate removal.
Beside the obvious advantages of being self-priming, having no moving parts, and requiring no lubrication, eductors can be made from any machinable material in addition to special materials, such as, tubing, heat-resistant glass, and fiberglass. The applications throughout industry are too numerous to mention, but some of the more common will be discussed here. The type of eductor is determined by the service intended.
The elements of a fluid eductor design are shown in Figure 1.
Eq. 1,
Operating head
h1 = P1 - Ps / γ1
Discharge head
hd = P2 - Ps / γ2
The head ratio RH is defined as the ratio of the operating head to the discharge head:
Eq. 3
Head Ratio
RH = [ ( P1 - Ps ) / γ1 ] / [ ( P2 - Ps ) / γ2 ] = [ ( P1 - Ps ) γ2 ] / [ ( P2 - Ps ) γ1 ]
Because ratios are involved, it is convenient to replace specific weight with specific gravity:
Eq. 4
Head Ratio
RH = [ ( P1 - Ps ) ( sp. gr.2 ) ] / [ ( P2 - Ps ) ( sp. gr.1 ) ]
When the suction and motive fluids are the same, no gravity correction is required and Eq. 4 becomes
Eq. 5
Head Ratio
RH = ( H1 - Hs ) / ( H2 - Hs )
Eq. 6
Operating head
h1 = H1 - Hs
Eq. 7
Discharge head
hd = H2 - Hs
Where
h1 = operating head, ft, (m)
hd = discharge head, ft, (m)
P1 = static pressure upstream, lb/ft2 (N/m2)
P2 = static pressure at discharge, lb/ft2 (N/m2)
Ps = static pressure at suction (nozzle tip), lb/ft2 (N/m2)
V velocity, ft/s (m/s)
γ1 = specific weight (force) of motive fluid, lb/ft3 (N/m3)
γ2 = specific weight (force) of mixed fluids, lb/ft3 (N/m3)
*A short tube has a length less than approximately 3 diameters.
Figure 1 - Eductor elements and terminology
Pump Handbook, Third Edition
Igor J. Karassik
Joseph P. Messina
Paul Cooper
Charles C. Heald
- Pelton Impulse Water Turbine Design Formulas This is a water turbine in which the pressure energy of the water is converted wholly to kinetic energy in one or more jets which impinge on buckets disposed around the periphery of a wheel.
- Progressive Cavity Pumps Review Progressing cavity pump" is a pump that transfers fluid through a sequence of small, fixed shape cavities as an helix shaped rotor is rotated.
- Reciprocating Air Compressor Pump Equation Reciprocating Type Air Compressors consists of one or more cylinders with cranks, connecting rods and pistons.
- Siphon Flow Rate Equation and Calculator
- Siphon Flow and Discharge Rates
- Fluid Discharged Distance Coordinates Equations and Calculator
- Vertical Tank Draining Time Formulas and Calculator
- Hooghoudt's Drainage Rate Equation and Calculator
- Time to Drain a Conical Tank Equation and Calculator
- Spherical Tank Draining Time Formulas and Calculator
