Tensile Thread Stress Area Equation and Calculator less than 100 ksi
Standard ANSI Hardware
Fastener - Bolt Design Calculations
This calculator requires a java - enabled browser)
This calculator calculates the tensile stress area of a screw thread fastener. Use this calculator for materials less than 100,000 psi ultimate tensile strength.
The critical areas of stress of mating screw threads are:
Negative Tolerance numbers indicate interference.
This calculator will calculate the unknown for the given conditions. Two (2) inputs are required, See the application illustration at bottom of page.
At = tensile strength area of screw thread.
D = Basic major diameter, example; .500 for a 1/2 - 13 UNC - 2B Thread Engineering Data Chart
n = Number of threads per inch
Equation:
This equation provides an approximate result by extrapolation on the thread stress area of a fastener.This equation is adequate for design applications on engineering materials or less than 100 ksi ultimate strength.
