Beam Deflection Deflection and Stress Calculator Equations for Fixed at Both Ends, Load at Center
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends, Load at Center.
Beam Moment and Loads at Supports
M = Wl/8
W1=W/2
Open: Moment and Loads at Supports Calculator
Beam Section Modulus Z
Z = I/z
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
Beam Stress Between each end and load
Open: Stress Between Each Support and Load Calculator
Beam Stress at Critical Locations/Points
Beam Stress at ends
Beam Stress at Load
Open: Stress at each end and at Load Calculator
Note: These are the maximum Beam stresses and are equal and opposite.
Stress is zero at x = (1⁄/4)l
Beam Deflection at any Point
Maximum Beam deflection, at load
Open: Stress at each End and at Load Calculator
E = Modulus of Elasticity psi
(N/mm2)
W =   Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
a, b, c & d = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 405 or,
  • Machinery's Handbook, 23st Edition, Page 261 or,
  • Machinery's Handbook, 27st Edition, Page 26
