Beam Deflection and Stress Equations for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
Shear, Deflection and Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
Beam Bending Moments Equation
W = | Beam Load, Total | lbf | (N) |
w = | Beam Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Shear Load | lbf | (N) |
Mmax = | Beam Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Tapered Load
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Reversed Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limited Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Reversed Limited Tapered Load
- Beam Supported One End, Pin Opposite End and Partial Distributed Load Deflection, Shear and Stress Equations and Calculator
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
