Beam Deflection Calculator, Shear and Stress Equations for a Beam supported One End Cantilevered with Reversed Tapered Load
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limted Tapered Load
Beam Moments Equation
Beam Stress Maximum
W = | Beam Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Beam Shear Load | lbf | (N) |
Mmax = | Beam Moment | lbs-in | (N-mm) |
θmax = | Beam Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Deflection Equations / Calculation Supported on Both Ends Uniform Loading
- Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
- Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
- Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
- Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
- Stress Equations and Calculator for a Beam supported One End, One End, Cantilevered at Defined Location and Distributed Load Between Supports
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
