Beam Deflection and Stress Equations and Calculator Beam Uniform Loading On Cantilevered End
Stress Deflection Equations and Calculator Beam Supported Uniform loading Applied on Catilevered End
Reaction and Shear Equation
Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
y = Deflection inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
