Beam Deflection and Stress Equations Calculator for Beam Ends Overhanging Supports and a Two Equal Loads Applied at Symmetrical Locations
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations.
Open
Beam Stress, Beam Deflection Two Equal Loads Applied Symmetrical Locations Calculator
Beam Stress between loads and nearest support
Beam Stress between the two supports
Beam Stress at supports and all point along length between supports
Beam Deflection between load nearest (adjacent) support
Beam Deflection between supports
Beam Deflection at the loads
Beam Deflection at the center of the beam
W = | Load | lbs | (N) |
s = | Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
u = | Some distance as indicated | inches | (mm) |
c = | Some distance as indicated | inches | (mm) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 407 or,
- Machinery's Handbook, 23st Edition, Page 263 or,
- Machinery's Handbook, 27st Edition, Page 264
- Combined Rectangular Cantilever Beam in Direct Compression and Beam Equations and Calculator
- Combined Rectangular Cantilever Beam in Direct Tension and Beam Equations and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Compression and Beam Equation and Calculator
- Combined Loading on Circular Beam or Shaft in Direct Tension and Beam Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Compression and Beam Equation and Calculator
- Combined Loading on Rectangular Beam or Shaft in Direct Tension and Beam Equation and Calculator
- Combined Loading on Circular Shaft in Direct Compression and Torsion Equation and Calculator
- Combined Loading on Circular Shaft in Direct Tension and Torsion Equation and Calculator
- Maximum Shear Stress Theory Fatigue of a Shaft or Axle Formula and Calculator
- Shaft Torsional Deflection and Rigidity Formulas and Calculator
- Static Loading Shaft or Axle Analysis Formula and Calculator - Most shafts are subject to combined bending and torsion, either of which may be steady or variable. Maximum Shear Stress and Von Mises Stress
