Circular Beam Combined Loading Simply Supported Equations and Calculator
Combined Loading on Circular Beam or Shaft in Direct Compression and Bending Equation and Calculator:
Maximum Nominal
Shear Stress
d = | Diameter | inches | (mm) |
L = | Length of Beam | inches | (mm) |
Fy = |
Applied Load | lbs | (N) |
Fx = | Applied Load | lbs | (N) |
σ' a = |
Stress, Tensile or Compressive | Lbs/in2 | (N/mm2) |
σ' b = | Stress, Tensile or Compressive | Lbs/in2 | (N/mm2) |
τ'a = | Stress , Max. Nominal Shear | Lbs/in2 | (N/mm2) |
τ'b = | Stress , Max. Nominal Shear | Lbs/in2 | (N/mm2) |
- Machinery's Handbook, 21st Edition, Page 404 or,
- Machinery's Handbook, 23st Edition, Page 260 or,
- Machinery's Handbook, 27st Edition, Page 261
- Beam Bending Equations / Calculation Supported on Both Ends Uniform Loading
- Beam Bending Equations / Calculation Supported on Both Ends Single Load at Center
- Beam Bending Equations / Calculation Supported on Both Ends Loaded at any Location
- Beam Bending Equations / Calculation Free and Guided on One End, Rigid one End With Uniform Load
- Beam Bending Equations / Calculation Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Bending Equations / Calculation Supported on Both Ends Loaded Two equal Loads
- Beam Bending Equations / Calculation with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Bending Equations / Calculation with End Overhanging Supports and a Single Load
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
