Angle of Twist Shaft Subjected to Torque Formula and Calculator
Strength of Materials Basics and Equations
Bearing Application, Specifications and Engineering
Angle of Twist - Shaft Subjected to Torque Formula and Calculator
This calculator will determine the angle of twist due to the applied torque on a shaft - results given in radians or and degrees
Modulus of Elasticity
G = E / ( 2 ( 1 + ν ) )
Polar Moment of Inertia
J = π ( Do4 - Di4 ) / 32
Eq. 3
Angle of Twist
θ = T L / ( G J )
rad to deg conversion
( 1 rad ) x ( 57.2957795 deg / rad) = 57.2957795 radians
E = Modulus of Elasticity (psi, Pa)
ν = Poisson Ratio (dimensionless)
Do = Shaft Outer Diameter (ft, m)
Di = Shaft Inner Diameter (ft, m)
T = Torque applied (ft-lbf, N-m)
L = Length of Section (ft, m)
G = Modulus of Rigidity (psi, Pa)
J = Polar Moment of Inertia (ft4, m4)
θ =Shaft Angle of Twist (rad)
Reference: Reference: Samuel. E Robello. 501 Solved Problems and Calculations for Drilling Operations. Sigma Quadrant. 2015. Houston, Texas, Page: 369.
- Torsional Deflection of a Shaft
- Structural Steel AISC Shapes Properties Viewer
- Polar Area Moment of Inertia
- Young's Modulus
- Solid Rigid Shaft to Shaft Couplings Design Equations and Calculator
- Torsion Stress Calculator and Equations Torsion is the twisting of an object due to an applied torque . It is expressed in newton meters (N-m) or foot-pound force (ft-lbf).
- Power Transmission Shaft Design Formulas and Calculator for Torsional Stress, Deflection Calculator for Stress and Tensile or Compressive Stress.
- Modulus of Elasticity, Youngs Modulus Table and Calculator
- Modulus of Elasticity Young's Modulus Strength for Metals - Iron and Steel
- Spring Materials Modulus of Elasticity used in Torsion and Tension
- Modulus of Elasticity, Strength Properties of Non-Metals Ultimate Strength, Yield Strength
- Ultimate Strength, Modulus of Elasticity, Yield Point of Metals Table Chart
- Poisson's Ratio Metals Materials Chart
- Fastener, Bolt and Screw Design Torque and Force Calculation
- Fastener and Screw Torque Design and Equation and Calculator
- Shear Modulus of Rigidity Table of Engineering Materials
- Polar Mass Moment of Inertia About Axis A-A and B-B of Common Shapes
- Polar Moment of Inertia, Polar Section Modulus Properties of Common Shapes
- Machine Design Application, Equations and Calculators , Scissor Lift Design, Sling Capacity Calculator, Pulley Design
