Annular Capacity Flow Casing Formula and Calculator
Pressure Vessel Pipes Design Engineering ASME
Annular Capacity Between Casing or Hole and Drill Pipe, Tubing, or Casing Formula and Calculator
Annular Capacity bbl/ft
Ca = ( Dh2 - Dp2 ) / 1029.4
Annular Capacity ft/bbl
Ca = 1029.4 / ( Dh2 - Dp2 )
Eq. 3
Annular capacity, gal/ft
Ca = ( Dh2 - Dp2 ) / 24.51
Eq. 4
Annular capacity, ft/ga
Ca = 24.51 / ( Dh2 - Dp2 )
Eq. 5
Annular capacity, ft3/Iinft
Ca = ( Dh2 - Dp2 ) / 183.35
Eq. 6
Annular capacity, linft/ft3
Ca = 183.35 / ( Dh2 - Dp2 )
Ca = Annular capacity
Dh =Casing or Hole size ID (in.)
Dp = Drill pipe OD (in.)
Reference: Lapeyrouse, N. J., 2012, Formulas and Calculations for Drilling, Production and Workover, Third Edition
- Orifice Plate Flow Calculations and Design
- Orifice Plate Type Flow Detector Review
- Orifice Submerged in Liquid Discharge Rate Calculator and Equation
- Pipe Friction Equations Within Pipe For Fluid Flow
- Pressure Drop Along Pipe Length - Fluid Flow Hydraulic and Pneumatic
- API Casing Data Tables Sizes 11.750 - 13.375
- API Casing Data Tables sizes 5.00 - 5.50
- API Tubing Grade & Specifications
- API Casing Data Tables Sizes 7.000 - 7.625
- Flow Capacity Pipe and Tubes ANSI Schedule 40 Air
- Pipe Flow Gradual Size Enlargement Formula and Calculator
- Velocity and Flow Capacity of Oil Schedule 80 Pipe
- Hazen-Williams Equation for Pipe Friction and Pressure Drop - Fluid Flow Hydraulic and Pneumatic
