API Casing Data Tables Size 11.750 - 13.375
Fluid Flow Table of Contents
API Casing Data Tables Size 11.750 - 13.375.
Specification 5C3 of the American Petroleum Institute standardizes 14 casing sizes from 4.5 inches (11.43 cm) to 20 inches (50.80 cm) outside diameter ("OD"). This and related API documents also promulgate standards for the threaded end finish, the wall thickness (several are available in each size to satisfy various design parameters, and in fact are indirectly specified by standardized nominal weights per linear foot; thicker pipe obviously being heavier), and the strength and certain chemical characteristics of the steel material. Several material strengths: termed "Grades" and ranging from 40,000 pounds per square inch (276 MPa) to 150,000 pounds per square inch (1,034 MPa) minimum yield strength—are available for most combinations of OD and wall thickness to meet various design needs.
O.D.
(inch)
Nominal
Weight
T & C
Grade
Internal Yield Pressure
Minimum Yield (psi)
Joint Strength
1000 lbs
PE
STC
LTC
STC
STC
LTC
BTC
13.500
81.40
H2S-90
6770
6770
1862
13.500
81.40
S-95
7140
7140
1948
13.500
81.40
H2S-95
7140
7140
1905
13.500
81.40
HCP-110
8270
8270
2235
13.500
81.40
P-110
8270
8270
2235
13.500
81.40
HCQ-125
9400
9400
2479
13.500
81.40
Q-125
9400
9400
2479
13.625
88.20
H2S-90
7220
7220
1801
13.625
88.20
S-95
7630
7630
1885
13.625
88.20
H2S-95
7630
7630
1843
13.625
88.20
HCP-110
8830
8830
2163
13.625
88.20
P-110
8830
8830
2163
13.625
88.20
HCQ-125
10030
10030
2399
13.625
88.20
Q-125
10030
10030
2399
16.000
65.00
H-40
1640
1640
1640
439
781
16.000
75.00
J-55
2630
2630
2630
710
1200
16.000
75.00
K-55
2630
2630
2630
752
1331
16.000
75.00
LS-65
3110
3110
3110
832
1394
16.000
84.00
J-55
2980
2980
2980
817
1351
16.000
84.00
K-55
2980
2980
2980
865
1499
16.000
84.00
LS-65
3520
3520
3520
957
1570
16.000
84.00
N-80
4330
4330
4330
1167
1898
16.000
84.00
HCN-80
4330
4330
4330
1342
1898
16.000
84.00
HCP-110
5960
5960
5960
1575
2518
16.000
84.00
P-110
5960
5960
5960
1575
2518
16.000
84.00
HCQ-125
6770
6770
6770
1773
2809
16.000
84.00
Q-125
6770
6770
6770
1773
2809
16.000
95.00
N-80
4950
4950
2161
16.000
95.00
HCN-80
4950
4950
2161
16.000
95.00
HCP-110
6810
6810
2866
16.000
95.00
P-110
6810
6810
2866
16.000
95.00
HCQ-125
7740
7740
3198
16.000
95.00
Q-125
7740
7740
3198
16.000
97.00
N-80
5030
5030
2194
16.000
97.00
HCN-80
5030
5030
2194
16.000
97.00
HCP-110
6920
6920
2910
16.000
97.00
P-110
6920
6920
2910
16.000
97.00
HCQ-125
7860
7860
3246
16.000
97.00
Q-125
7860
7860
3246
16.000
109.00
J-55
3950
3950
3950
1116
1772
16.000
109.00
K-55
3950
3950
3950
1181
1965
16.000
109.00
N-80
5740
5740
5740
1594
2489
16.000
118.00
J-55
4300
4300
4300
1224
1924
16.000
118.00
K-55
4300
4300
4300
1296
2131
16.000
118.00
N-80
6260
6260
6260
1741
2703
18.625
87.50
H-40
1630
1630
1630
559
993
18.625
87.50
J-55
2250
2250
2250
754
1329
18.625
87.50
K-55
2250
2250
2250
794
1427
18.625
87.50
N-80
3270
3270
3270
1079
1887
18.625
94.50
H-40
1760
1760
1760
609
1067
18.625
94.50
J-55
2420
2420
2420
821
1427
18.625
94.50
K-55
2420
2420
2420
865
1533
18.625
94.50
N-80
3520
3520
3520
1174
2027
18.625
106.00
H-40
2000
2000
2000
703
1206
18.625
106.00
J-55
2740
2740
2740
948
1613
18.625
106.00
K-55
2740
2740
2740
998
1733
18.625
106.00
N-80
3990
3990
3990
1356
2292
18.625
117.50
H-40
2230
2230
2230
795
1342
18.625
117.50
J-55
3060
3060
3060
1072
1795
18.625
117.50
K-55
3060
3060
3060
1129
1929
18.625
117.50
N-80
4460
4460
4460
1534
2551
O.D.
(inch)
Nominal
Weight
T & C
Grade
Collapse
Pressure
(psi)
Body Yield
1000 lbs
Wall
(inch)
I.D.
(inch)
Drift Diameter
(inch)
API
LSS
13.500
81.40
H2S-90
4860
2119
0.580
12.340
13.500
81.40
S-95
4860
2236
0.580
12.340
13.500
81.40
H2S-95
4860
2236
0.580
12.340
13.500
81.40
HCP-110
4860
2590
0.580
12.340
13.500
81.40
P-110
3910
2590
0.580
12.340
13.500
81.40
HCQ-125
4860
2943
0.580
12.340
13.500
81.40
Q-125
4030
2943
0.580
12.340
13.625
88.20
H2S-90
5930
2297
0.625
12.375
13.625
88.20
S-95
5930
2425
0.625
12.375
13.625
88.20
H2S-95
5930
2425
0.625
12.375
13.625
88.20
HCP-110
5930
2808
0.625
12.375
13.625
88.20
P-110
4570
2808
0.625
12.375
13.625
88.20
HCQ-125
5930
3191
0.625
12.375
13.625
88.20
Q-125
4800
3191
0.625
12.375
16.000
65.00
H-40
630
736
0.375
15.250
15.062
16.000
75.00
J-55
1020
1178
0.438
15.124
14.936
16.000
75.00
K-55
1020
1178
0.438
15.124
14.936
16.000
75.00
LS-65
1020
1392
0.438
15.124
14.936
16.000
84.00
J-55
1410
1326
0.495
15.010
14.822
16.000
84.00
K-55
1410
1326
0.495
15.010
14.822
16.000
84.00
LS-65
1470
1567
0.495
15.010
14.822
16.000
84.00
N-80
1480
1929
0.495
15.010
14.822
16.000
84.00
HCN-80
1910
1929
0.495
15.010
14.822
16.000
84.00
HCP-110
1910
2652
0.495
15.010
14.822
16.000
84.00
P-110
1480
2652
0.495
15.010
14.822
16.000
84.00
HCQ-125
1910
3014
0.495
15.010
14.822
16.000
84.00
Q-125
1480
3014
0.495
15.010
14.822
16.000
95.00
N-80
2180
2196
0.566
14.868
16.000
95.00
HCN-80
2580
2196
0.566
14.868
16.000
95.00
HCP-110
2580
3019
0.566
14.868
16.000
95.00
P-110
2230
3019
0.566
14.868
16.000
95.00
HCQ-125
2580
3431
0.566
14.868
16.000
95.00
Q-125
2230
3431
0.566
14.868
16.000
97.00
N-80
2270
2230
0.575
14.850
16.000
97.00
HCN-80
2990
2230
0.575
14.850
16.000
97.00
HCP-110
2990
3067
0.575
14.850
16.000
97.00
P-110
2340
3067
0.575
14.850
16.000
97.00
HCQ-125
2990
3485
0.575
14.850
16.000
97.00
Q-125
2340
3485
0.575
14.850
16.000
109.00
J-55
2560
1739
0.656
14.688
14.500
16.000
109.00
K-55
2560
1739
0.656
14.688
14.500
16.000
109.00
N-80
3080
1739
0.656
14.688
14.500
16.000
118.00
J-55
3170
1889
0.715
14.570
14.382
16.000
118.00
K-55
3170
1889
0.715
14.570
14.382
16.000
118.00
N-80
3680
2747
0.715
14.570
14.382
18.625
87.50
H-40
630
995
0.435
17.755
17.567
18.625
87.50
J-55
630
1368
0.435
17.755
17.567
18.625
87.50
K-55
630
1368
0.435
17.755
17.567
18.625
87.50
N-80
630
1990
0.435
17.755
17.567
18.625
94.50
H-40
780
1068
0.468
17.689
17.501
18.625
94.50
J-55
780
1469
0.468
17.689
17.501
18.625
94.50
K-55
780
1469
0.468
17.689
17.501
18.625
94.50
N-80
780
2137
0.468
17.689
17.501
18.625
106.00
H-40
1140
1208
0.531
17.563
17.375
18.625
106.00
J-55
1140
1661
0.531
17.563
17.375
18.625
106.00
K-55
1140
1661
0.531
17.563
17.375
18.625
106.00
N-80
1150
2416
0.531
17.563
17.375
18.625
117.50
H-40
1500
1344
0.593
17.439
17.251
18.625
117.50
J-55
1510
1849
0.593
17.439
17.251
18.625
117.50
K-55
1510
1849
0.593
17.439
17.251
18.625
117.50
N-80
1620
2689
0.593
17.439
17.251
Related Resources:
