Dowel Pin Shear Load Stress Equations and Calculator
Civil Engineering and Design
Pin, Dowel Design Length Shear Stress and Contact Pressure Check Equations and Calculator
The following equations can be used for wood dowels or other pin materials single shear design and analysis.
Preview Pin, Dowel Design Length Shear Stress and Contact Pressure Check Equations and Calculator
Pin Dowel Shear Stress Equation:
τ = ( 4 · F ) / ( π · d2 ) ≤ τA
τA = su / fos
Contact Pressure Design Equation:
p1 = F / ( d · s1 ) ≤ p1A
p1A = su1 / fos
p2 = F / ( d · s2 ) ≤ p2A
p2A = s2 / fos
where:
F = Force applied (lbs, N),
τ = shear stress on dowel pin [psi, MPa],
τA = allowable shear stress [psi, MPa],
su = Shear or yield strength of dowel pin material [psi, MPa],
fos = Factor of safety for dowel pin and boards, typical 2 or greater,
d = pin diameter [in, mm],
p1 = pressure in the top board [psi, MPa],
p2 = pressure in the bottom board [psi, MPa],
p1A = allowable pressure in the top board [psi, MPa],
p2A = allowable pressure in the bottom board [psi, MPa],
s1 = thickness of the top board [in, mm],
s2 = thickness of the bottom board [in, mm].
Kent's Machine Engineers Handbook, 12th Edition Design and Production, 1950 Colin Carmichael
