Pipe Stress Due to Sustained Loads Formulae and Calculator
Pipe Stress Due to Sustained Loads Calculator and Equations per. ASME B31.3 - 2020
The equation for the stress due to sustained loads, such as pressure and weight, SL is given in Eq. 1. Equations for the stress due to sustained bending moments Sb, is given in Eq. 2.
Preview: Pipe Stress Due to Sustained Loads Calculator
SL = [ ( | Sa | + Sb )2 + ( 2 · St )2 ]0.5
Sb = [ ( Ii · Mi )2 + ( Io · Mo )2 ]0.5 / Z
Eq. 3
St = ( It · Mt ) / ( 2 · Z )
Eq. 4
Sa = ( Ia · Fa ) / Ap
SL = stress due to sustained loads
Sa = axial stress range due to displacement strains
Sb = bending stress range due to displacement strains
St = torsional stress-range due to displacement strains
Ii = sustained in-plane moment index. In the absence of more-applicable data, Ii is taken as the greater of 0.75Ii or 1.00.
Io = sustained out-plane moment index.In the absence of more-applicable data, Io mistaken as the greater of 0.75Io or 1.00.
It = sustained torsional moment index. In the absence of more applicable data, It is taken as 1.00.
Ia
= sustained longitudinal force index. in the adsence of more applicable data, Ia is taken as 1.00.
Mi = in-plane moment due to sustained loads,e.g., pressure and weight
Mo = out-plane moment due to sustained loads,e.g., pressure and weight
Mt = torsional moment due to sustained loads, e.g. pressure and weight
Z = sustained section modulus of pipe.
Ap = cross sectional area of the pipe, considering pipe dimensions less allowance
Fa = longitudinal force due to sustained loads, e.g. pressure and weight
ASME B31.1-2020, Paragraph 320.2
- Section Modulus Pipe Calculator
- Allowable Stresses for Pipe and Tube B36.10M
- Pipe Stress Clamping Force
- L Pipe Bend Guided Cantilever Beam Equation and Calculator
- Pipe Thread Installation Torque Table Chart
- Torsional Deflection Stress Pipe Equation and Calculator
- Schedule 40 Steel Pipe Sizes & Dimensions ANSI
- Schedule 80 Steel Pipe Sizes and Dimensions ANSI
- Pipe Enlargement and Reduction Head, Heat and Minor Losses Formula
- Flow Rate of Steam in Schedule 40 Pipe Tables
- API Integral-Joint tubing Recommended Torque Table API IJ integral-joint tubing is available in OD sizes of 1.315 to 2.063 in.
- Design for Pipe and Tube Forming Premium Membership Required
- Section Modulus Properties Equations Calculators
- Section Modulus, Radii of Gyration Circular, Eccentric Shape Equations
- Hollow Cylinder Mass Moment of Inertia
- Thin Wall Shaft Mass Moment of Inertia
- Torsional Deformation and Stress Concentric Circular Section Equations and Calculator . Torsional deflection and stress of a pipe.
- Circular Ring Analysis No 16 Roarks Formulas for Stress and Strain Equations and Calculator
- Circular Ring Moment, Hoop Load, and Radial Shear Equations and Calculator #20
- Weight Mass of Pipe Hollow Cylinder Equation and Calculator
- Section Properties Tube/Pipe at Center
- Minimum Pipe Insulation Thickness, in. per. ASHRAE Table, Formula and Calculator
