Toggle Clamp Mechanism no. 5 Formula and Calculator
Manufacturing Toggle Mechanism Spring Loaded Ninety Degree Design Formula and Calculator
Preview: Clamping Ninety Degree Reaction Points Toggle Mechanism Calculator
Figure 1 Toggle Mechanism
Q = [ P · ( l + l1 / l1 ) + q ] · (l2 / l3 ) · ( 1 / n)
Q = Qo ( l2 / l3 ) ( 1 / n )
Eq. 3
Qo = P ( ( l + l1 ) / l1 ) + q
Q = force applied to handle. lbf, (N)
Qo = force applied lbf, (N)
P = clamping force, lbf. (N)
q = spring resistance, lbf. (N)
n = efficiency coefficient, 0.98 to 0.84
l, l1, l2, l3 = length as indicated. in, (mm)
Handbook of Machining and Metalworking Calculations
Ron A. Walsh
2001
- Pivot Arm Toggle Formulae and Calculator
- Triangular Clamping Toggle Design Formula and Calculator
- Work Holding Toggle Mechanism Calculations
- Toggle Clamp Equations and Calculator
- Toggle Clamps Animation
- Toggle Clamping Mechanism Formula and Calculator
- Mechanisms in Modern Engineering Design
- Theory of Mechanisms and Machines
- Ingenious Mechanisms Volume I for Designers and Inventors
- Ingenious Mechanisms Volume II for Designers and Inventors
- Simple Mechanical Levers Equations and Calculators
- Adding Forces by the Parallelogram Resultant of Two Forces Equation and Calculator
- Geneva Mechanism External Design Calculator and Equations
