Design Equations and Formula Circular Pitches and Equivalent Diametral Pitches Table
Gear Design and Selection Application
Spur Gear Calculator and Geometry Generator - Download DXF, SVG, csv file.
Spur Gear and Assembly Builder - Download DXF, SVG ***
Spur Gear design formula for geometry, pitch, tooth clearance and critical functional data.
(Inch Units Applicable for Constants)
Gear Nomenclature
Spur Gear Design Calculator
φ = Pressure Angle
a = Addendum
aG = Addendum of Gear
aP = Addendum of Pinion
b = Dedendum
c = Clearance
C = Center Distance
D = Pitch Diameter
DG = Pitch Diameter of Gear
DP = Pitch Diameter of Pinion
DB = Base Circle Diameter
DO = Outside Diameter
DR = Root Diameter
F = Face Width
hk = Working Depth of Tooth
ht = Whole Depth of Tooth
mG = Gear Ratio
N = Number of Teeth
NG = Number of Teeth in Gear
NP = Number of Teeth in Pinion
p = Circular Pitch
P=Diametral Pitch
Equations for Standards Spur Gears
To Find Equation
Base Circle Pitch DB = D cosφ
Circular Pitch
p = ( π D )/ N
p = π / P
Center Distance C = Np (mG + 1) / 2P
C = ( Dp + DG ) / 2
C = ( NG + Np ) / 2P
C = (NG + Np) p / 2P
C = (NG + Np) p / 6.2832
Diametral Pitch
P = π / p
P = N / D
P = [ Np ( mG + 1) ] / 2C
Gear Ratio mG = NG / Np
Number of Teeth N = P D
N = ( π D ) / p
Outside Diameter
(Full Depth Teeth)
DO = ( N + 2 ) / P
DO = [ ( N + 2 ) p ] / π
Outside Diameter
(American Standard
Stub Teeth)
DO = ( N + 1.6 ) / P
DO = [ ( N + 1.6 ) p ] / π
Outside Diameter DO = D + 2a
Pitch Diameter D = N / P
D = (N p ) / π
Root Diameter DR = D - 2b
Whole Depth a + b
Working Depth aG + ap
Formulas for Tooth Parts, 20-and 25-degree Involute Full-depth Teeth
ANSI Coarse Pitch Spur Gear Tooth Forms ANSI B6.1
To Calculate
Diametral Pitch,
P, Known
Circular Pitch,
p, Known
Addendum
a = 1.000 / P
a = 0.3183 × p
Dedendum (Preferred)
b = 1.250 / P
b = 0.3979 × p
(Shaved or Ground Teeth)a
b = 1.350 / P
b = 0.4297 × p
Working Depth
hk = 2.000 / P
hk = 0.6366 × p
Whole Depth (Preferred)
ht = 2.250 / P
ht = 0.7162 × p
ht = 2.350 / P
ht = 0.7480 × p
Clearance (Preferred)b
c = 0.250 / P
c = 0.0796 × p
c = 0.350 / P
c = 0.1114 × p
Fillet Radius (Rack)c
rf = 0.300 / P
rf = 0.0955 × p
Pitch Diameter
D = N / P
D = 0.3183 × Np
Outside Diameter
DO = (N + 2) / P
DO = 0.3183 × (N + 2) p
Root Diameter (Preferred)
DR = (N − 2.5) / P
DR = 0.3183 × (N − 2.5) p
Root Diameter
DR = (N − 2.7) / P
DR = 0.3183 × (N − 2.7) p
Circular Thickness Basic
t = 1.5708 / P
t = p / 2
Equations Tooth Parts, 20-and 25-degree Involute Full-depth Teeth ANSI Coarse Pitch Spur Gear Tooth Forms ANSI B6.1
a When gears are preshave cut on a gear shaper the dedendum will usually need to be increased to 1.40/P to allow for the higher fillet trochoid produced by the shaper cutter. This is of particular importance on gears of few teeth or if the gear blank configuration requires the use of a small diameter shaper cutter, in which case the dedendum may need to be increased to as much as 1.45/P. This should be avoided on highly loaded gears where the consequently reduced J factor will increase gear tooth stress excessively.
b A minimum clearance of 0.157/P may be used for the basic 20-degree and 25-degree pressure angle rack in the case of shallow root sections and use of existing hobs or cutters.
c The fillet radius of the basic rack should not exceed 0.235/P for a 20-degree pressure angle rack or 0.270/P for a 25-degree pressure angle rack for a clearance of 0.157/P. The basic rack fillet radius must be reduced for teeth with a 25-degree pressure angle having a clearance in excess of 0.250/P.
Helical Gear
Calculate
When Defined
Formula
Normal D.P. (Pn)
Transverse D.P.(P) and
the Helix Angle (A)
Pn= P / cos A
Normal D.P. (Pn)
Number of teeth (N) and
the Helix Angle (A)
Pn= N / (D X cos A)
Pitch Diameter (D)
Number of teeth (N), the Normal Diametral Pitch
and the Helix Angle (A)
D = N / (Pn X cos A)
Outside Diameter (OD)
Pitch Diameter (D) and the Addendum (a)
OD = D + (2 X a)
Normal Diametral Pitch (P) and
the Pitch Diameter (D)
OD = D + 2/Pn
Helix Angle (A) for Parallel Shaft Drive
Number of Teeth (N), Pitch Diameter (D) and
the Diametral Pitch (P)
Cos A = N / (Pn X D)
Addendum (a)
Normal Diametral Pitch (Pn)
a = 1 / Pn
Lead (L)
Pitch Diameter (D) and Pitch Helix Angle
L = (pi*D) / Tan
Circular Pitch
Diametral Pitch
Module
Arc Thickness
of Tooth on Pitch Line
Addendum
Working Depth
of Tooth
Dedendum or Depth
of Space Below Pitch Line
Whole Depth
of Tooth
4 0.7854 32.3402 2.0000 1.2732 2.5464 1.4732 2.7464
3 - 1/2 0.8976 28.2581 1.7500 1.1140 2.2281 1.2890 2.4031
3 1.0472 24.2552 1.5000 0.9549 1.9098 1.1049 2.0598
2 - 3/4 1.1424 22.2339 1.3750 0.8753 1.7506 1.0128 1.8881
2 - 1/2 1.2566 20.2117 1.2500 0.7957 1.5915 0.9207 1.7165
2 - 1/4 1.3963 18.1913 1.1250 0.7162 1.4323 0.8287 1.5448
2 1.5708 16.1701 1.0000 0.6366 1.2732 0.7366 1.3732
1 - 7/8 1.6755 15.1595 0.9375 0.5968 1.1937 0.6906 1.2874
1 - 3/4 1.7952 14.1488 0.8750 0.5570 1.1141 0.6445 1.2016
1 - 5/8 1.9333 13.1382 0.8125 0.5173 1.0345 0.5985 1.1158
1 - 1/2 2.0944 12.1276 0.7500 0.4775 0.9549 0.5525 1.0299
1 - 7/16 2.1855 11.6223 0.7187 0.4576 0.9151 0.5294 0.9870
1 - 3/8 2.2848 11.1169 0.6875 0.4377 0.8754 0.5064 0.9441
1 - 5/16 2.3936 10.6116 0.6562 0.4178 0.8356 0.4834 0.9012
1 - 1/4 2.5133 10.1062 0.6250 0.3979 0.7958 0.4604 0.8583
1 - 3/16 2.6456 9.6010 0.5937 0.3780 0.7560 0.4374 0.8154
1 - 1/8 2.7925 9.0958 0.5625 0.3581 0.7162 0.4143 0.7724
1 - 1/16 2.9568 8.5904 0.5312 0.3382 0.6764 0.3913 0.7295
1 3.1416 8.0851 0.5000 0.3183 0.6366 0.3683 0.6866
15/16 3.3510 7.5798 0.4687 0.2984 0.5968 0.3453 0.6437
7/8 3.5904 7.0744 0.4375 0.2785 0.5570 0.3223 0.6007
13/16 3.8666 6.5692 0.4062 0.2586 0.5173 0.2993 0.5579
3/4 4.1888 6.0639 0.3750 0.2387 0.4775 0.2762 0.5150
11/16 4.5696 5.5586 0.3437 0.2189 0.4377 0.2532 0.4720
2/3 4.7124 5.3903 0.3333 0.2122 0.4244 0.2455 0.4577
5/8 5.0265 5.0532 0.3125 0.1989 0.3979 0.2301 0.4291
9/16 5.5851 4.5479 0.2812 0.1790 0.3581 0.2071 0.3862
1/2 6.2832 4.0426 0.2500 0.1592 0.3183 0.1842 0.3433
7/16 7.1808 3.5373 0.2187 0.1393 0.2785 0.1611 0.3003
2/5 7.8540 3.2340 0.2000 0.1273 0.2546 0.1473 0.2746
3/8 8.3776 3.0319 0.1875 0.1194 0.2387 0.1381 0.2575
1/3 9.4248 2.6947 0.1666 0.1061 0.2122 0.1228 0.2289
5/16 10.0531 2.5266 0.1562 0.0995 0.1989 0.1151 0.2146
2/7 10.9956 2.3100 0.1429 0.0909 0.1819 0.1052 0.1962
1/4 12.5664 2.0213 0.1250 0.0796 0.1591 0.0921 0.1716
2/9 14.1372 1.7967 0.1111 0.0707 0.1415 0.0818 0.1526
1/5 15.7080 1.6170 0.1000 0.0637 0.1273 0.0737 0.1373
3/16 16.7552 1.5160 0.0937 0.0597 0.1194 0.0690 0.1287
1/6 18.8496 .5053 0.0833 0.0531 0.1061 0.0614 0.1144
Resources:
