Standard Pipe Schedules Pipe Sizes Chart Table Data
The following chart gives standard pipe schedule or pipes sizes as given by ANSI / ASME B36.10M and API 5L . Data given in based on the NPS Tables given by ANSI B36.10M and includes Pipe wall thickness, outside diameter, nominal diameter.
ANSI - American National Standards Institute
ASME - American Society of Mechanical Engineers
API = American Petroleum Institute
NPS = Nominal Pipe Size
O.D. =. Outside Diameter
E.H. = Extra Heavy
Dbl. = Double
Std. = Standard
Pipe size is specified by two designations: a nominal pipe size (NPS) for diameter based on inches, and a schedule (Sched. or Sch.) for wall thickness. NPS is often incorrectly called National Pipe Size, due to confusion with national pipe thread (NPT).
The European (ISO) designation equivalent to NPS is DN (diamètre nominal/nominal diameter/Durchmesser nach Norm), in which sizes are measured in millimetres. The term NB (nominal bore) is also frequently used interchangeably with NPS
Standard Pipe Schedules (40, 80, 160, etc..) Related Resources --> Bottom of this webpage
Nom. |
O.D. Inches
PIPE SCHEDULES
WALL THICKNESS ( Inches) |
5s | 5 | 10s | 10 | 20 | 30 | 40s & Std | 40 | ||
1/8 | .405 |
.035 | .049 | .049 | .068 | .068 | |||
1/4 | .540 |
.049 | .065 | .065 | .088 | .088 | |||
3/8 | .675 |
.049 | .065 | .065 | .091 | .091 | |||
1/2 | .840 |
.065 | .065 | .083 | .083 | .109 | .109 | ||
3/4 | 1.050 |
.065 | .065 | .083 | .083 | .113 | .113 | ||
1 | 1.315 |
.065 | .065 | .109 | .109 | .133 | .133 | ||
1 1/4 | 1.660 |
.065 | .065 | .109 | .109 | .140 | .140 | ||
1 1/2 | 1.900 |
.065 | .065 | .109 | .109 | .145 | .145 | ||
2 | 2.375 |
.065 | .065 | .109 | .109 | .154 | .154 | ||
2 1/2 | 2.875 |
.083 | .083 | .120 | .120 | .203 | .203 | ||
3 | 3.500 |
.083 | .083 | .120 | .120 | .216 | .216 | ||
3 1/2 | 4.000 |
.083 | .083 | .120 | .120 | .226 | .226 | ||
4 | 4.500 |
.083 | .083 | .120 | .120 | .237 | .237 | ||
4 1/2 | 5.000 |
.247 | |||||||
5 | 5.563 |
.109 | .109 | .134 | .134 | .258 | .258 | ||
6 | 6.625 |
.109 | .109 | .134 | .134 | .280 | .280 | ||
7 | 7.625 |
.301 | |||||||
8 | 8.625 |
.109 | .109 | .148 | .148 | .250 | .277 | .322 | .322 |
9 | 9.625 |
.342 | |||||||
10 | 10.750 |
.134 | .134 | .165 | .165 | .250 | .307 | .365 | .365 |
11 | 11.750 |
.375 | |||||||
12 | 12.750 |
.156 | .165 | .180 | .180 | .250 | .330 | .375 | .406 |
14 | 14.000 |
.156 | .188 | .250 | .312 | .375 | .375 | .437 | |
16 | 16.000 |
.165 | .188 | .250 | .312 | .375 | .375 | .500 | |
18 | 18.000 |
.165 | .188 | .250 | .312 | .437 | .375 | .562 | |
20 | 20.000 |
.188 | .218 | .250 | .375 | .500 | .375 | .593 | |
24 | 24.000 |
.218 | .250 | .250 | .375 | .562 | .375 | .687 | |
26 | 26.000 |
.312 | .500 | .375 | |||||
28 | 28.000 |
312 | .500 | .625 | .375 | ||||
30 | 30.000 |
.250 | .312 | .312 | .500 | .625 | .375 | ||
32 | 32.000 |
.312 | .500 | .625 | .375 | .688 | |||
34 | 34.00 |
36 | 36.000 |
.312 | .625 | .375 | .750 | ||||
42 | 42.000 |
.375 | |||||||
48 | 48.000 |
.375 |
Nom. |
O.D. Inches
PIPE SCHEDULES WALL THICKNESS ( Inches) |
60 | 80s & E.H. | 80 | 100 | 120 | 140 | 160 | Dbl. E.H. (XXH) |
1/8 | .405 |
.095 | .095 | ||||||
1/4 | .540 |
.119 | .119 | ||||||
3/8 | .675 |
.126 | .126 | ||||||
1/2 | .840 |
.147 | .147 | .187 | .294 | ||||
3/4 | 1.050 |
.154 | .154 | .218 | .308 | ||||
1 | 1.315 |
.179 | .179 | .250 | .358 | ||||
1 1/4 | 1.660 |
.191 | .191 | .250 | .382 | ||||
1 1/2 | 1.900 |
.200 | .200 | .281 | .400 | ||||
2 | 2.375 |
.218 | .218 | .343 | .436 | ||||
2 1/2 | 2.875 |
.276 | .276 | .375 | .552 | ||||
3 | 3.500 |
.300 | .300 | .437 | .600 | ||||
3 1/2 | 4.000 |
.318 | .318 | .636 | |||||
4 | 4.500 |
.281 | .337 | .337 | .437 | .531 | .674 | ||
4 1/2 | 5.000 |
.355 | .710 | ||||||
5 | 5.563 |
.375 | .375 | .500 | .625 | .750 | |||
6 | 6.625 |
.432 | .432 | .562 | .718 | .864 | |||
7 | 7.625 |
.500 | .875 | ||||||
8 | 8.625 |
.406 | .500 | .500 | .593 | .718 | .812 | .906 | .875 |
9 | 9.625 |
.500 | |||||||
10 | 10.750 |
.500 | .500 | .593 | .718 | .843 | 1.000 | 1.125 | |
11 | 11.750 |
.500 | |||||||
12 | 12.750 |
.562 | .500 | .687 | .843 | 1.000 | 1.125 | 1.312 | |
14 | 14.000 |
.593 | .500 | .750 | .937 | 1.093 | 1.250 | 1.406 | |
16 | 16.000 |
.656 | .500 | .843 | 1.031 | 1.218 | 1.437 | 1.593 | |
18 | 18.000 |
.750 | .500 | .937 | 1.156 | 1.375 | 1.562 | 1.781 | |
20 | 20.000 |
.812 | .500 | 1.031 | 1.280 | 1.500 | 1.750 | 1.968 | |
24 | 24.000 |
.968 | .500 | 1.218 | 1.531 | 1.812 | 2.062 | 2.343 | |
26 | 26.000 |
.500 | |||||||
28 | 28.000 |
30 | 30.000 |
.500 | |||||||
32 | 32.000 |
.500 | |||||||
34 | 34.00 |
36 | 36.000 |
.500 | |||||||
42 | 42.000 |
.500 | |||||||
48 | 48.000 |
.500 |
Resources of Interest
- National Standard Taper Pipe Threads NPT Chart
- Fluid Flow Engineering and Design Resoures
- Hydraulic, Pneumatic Engineering & Design
- Schedule 40 Steel Pipe Sizes & Dimensions ANSI
- Schedule 80 Steel Pipe Sizes & Dimensions ANSI
- Standard Size Steel Pipe Weights With Contents Calculator
- Xtra Strong (XS) Size Steel Pipe Weights Calculator
- Double Xtra Strong (XXS) Size Steel Pipe Weights Calculator
- Velocity and Flow Capacity of Oil Standard Tubes
- Velocity and Flow Capacity of Oil Schedule 40 Pipe
- Velocity and Flow Capacity of Oil Schedule 80 Pipe
- Velocity and Flow Capacity of Oil Schedule 160 Pipe
- Steel Pipe Flow Friction Loss for sizes 10" to 12 " inch diameter
- Friction Losses in Steel Pipes size 0.5 to 1.25 inch diameter
- Friction Loss in Steel Pipe 1.5" to 3" inch diameter
- Steel Pipe Flow Loss Friction for sizes 4 " to 8 " inch diameter
![Spider Optimizer](/graphics/spider_trap.gif)
© Copyright 2000 -
2024, by Engineers Edge, LLC
www.engineersedge.com
Disclaimer |
Feedback
Advertising
| Contact
