Related Resources: fluid flow
Friction Loss in Steel Pipe 1.5" to 3" inch diameter
Friction Loss in Steel Pipe size 1.5" to 3" inch diameter
Tables are for steel pipe with a surface roughness of C=100.
See also
- Steel Pipe Flow Friction Loss for sizes 10" to 12 " inch diameter
- Friction Losses in Steel Pipes size 0.5 to 1.25 inch diameter
- Steel Pipe Flow Loss Friction for sizes 4 " to 8 " inch diameter
To adjust for different surface roughness factors, use the following correction factors:
Value of C
150
140
130
120
110
100
90
80
70
60
0.47
0.54
0.62
0.71
0.84
1.00
1.22
1.51
1.93
2.57
Friction Losses in Pipe: Standard Weight Steel 1- 1/2" Dia.
Pipe Size, in.
1.5 |
Pipe Dia., in.
1.61 Velocity, fps |
Surface Rough C
100 hd. loss, ft/100 ft |
gpm
8
1.26
1.0
9
1.42
1.2
10
1.58
1.5
12
1.89
2.0
14
2.21
2.7
16
2.52
3.5
18
2.84
4.3
20
3.15
5.2
22
3.47
6.2
24
3.78
7.3
26
4.10
8.5
28
4.41
9.8
30
4.73
11.1
32
5.04
12.5
34
5.36
14.0
36
5.67
15.5
38
5.99
17.2
40
6.30
18.9
42
6.62
20.7
Friction Losses in Pipe: Standard Weight Steel 2" Dia.
Pipe Size, in.
2.0 |
Pipe Dia., in.
2.067 Velocity, fps |
Surface Rough C
gpm
14
1.34
0.8
16
1.53
1.0
18
1.72
1.3
20
1.91
1.6
22
2.10
1.9
24
2.29
2.2
26
2.49
2.5
28
2.68
2.9
30
2.87
3.3
32
3.06
3.7
34
3.25
4.1
36
3.44
4.6
38
3.63
5.1
40
3.82
5.6
42
4.02
6.1
44
4.21
6.7
46
4.40
7.3
48
4.59
7.8
50
4.78
8.5
Friction Losses in Pipe: Standard Weight Steel 2-1/2 " Dia.
Pipe Size, in. 2.5
Pipe Dia., in.
2.469 Velocity, fps |
Surface Rough C
gpm
26
1.74
1.06
28
1.88
1.22
30
2.01
1.39
32
2.14
1.56
34
2.28
1.75
36
2.41
1.94
38
2.55
2.15
40
2.68
2.36
42
2.81
2.58
44
2.95
2.81
46
3.08
3.1
48
3.22
3.3
50
3.35
3.6
55
3.69
4.3
60
4.02
5.0
65
4.36
5.8
70
4.69
6.6
75
5.03
7.5
80
5.36
8.5
85
5.70
9.5
90
6.03
10.6
95
6.37
11.7
100
6.70
12.8
110
7.37
15.3
120
8.04
18.0
Friction Losses in Pipe: Standard Weight Steel 3" Dia.
Pipe Size, in. 3.0
Pipe Dia., in.
3.068 Velocity, fps |
Surface Rough C
gpm
40
1.74
0.82
42
1.82
0.90
44
1.91
0.98
46
2.00
1.06
48
2.08
1.15
50
2.17
1.24
55
2.39
1.48
60
2.60
1.74
65
2.82
2.01
70
3.04
2.31
75
3.25
2.62
80
3.47
3.0
85
3.69
3.3
90
3.91
3.7
95
4.12
4.1
100
4.34
4.5
110
4.77
5.3
120
5.21
6.3
130
5.64
7.3
140
6.08
8.3
150
6.51
9.5
160
6.94
10.7
170
7.38
11.9
180
7.81
13.2
190
8.25
14.6
- Schedule 40 Pipe Dimensions
- Schedule 80 Pipe Dimensions
- Flow of Water in Pipes Equations and Calculator
- Flow Rate of Steam in Schedule 40 Pipe Tables
- Head Loss at Pipe Entrance Equations and Calculator using the head loss coefficient and head loss of a fluid at a smooth bellmouth pipe entrance.
- Head Loss at Pipe Abrupt Exit Equations and Calculator of a fluid.
- Head loss and head loss coefficient equation and calculator of a fluid in across a screen (circular metal wire mesh) inside a pipe.
- Air Pressure Loss per Foot in Steel Pipe Table Estimated pressure drop at the given CFM of free air flow for steel pipe.
- Flow Losses for Valves and Fittings in Equivalent Feet if Pipe.
- Fluid Energy Loss in Fittings and Valves Formula, Calculator and Tables
Source
