Beam Stress and Deflection Calculator Moment Applied at Defined Location
Beam Deflection, Stress, Strain Equations and Calculators
Beam Stress & Deflection Equations / Calculator Moment Applied at Defined Location
Preview Beam Stress and Deflection Calculator
Reaction and Shear Equation
Bending Moments Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
y = Deflection inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
θmax = Slope Angle radian
