Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
Structural Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
Beam Moments Equation
Stress Maximum Equation
W = | Beam Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Beam Shear Load | lbf | (N) |
Mmax = | Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Deflection Equations / Calculator Free and Guided on One End, Rigid one End With Uniform Load
- Beam Deflection Equations / Calculator Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Deflection Equations / Calculator Supported on Both Ends Loaded Two equal Loads
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
- Beam Deflection Equations / Calculatorn Cantilevered Beam with Uniform Load
