Bending, Deflection and Stress Equations Calculator for Simply Supported on Both Ends Under Superimposed Loading
Structural Beam Deflection, Stress, Bending Equations and calculator for a Simply Supported Beam on Both Ends Under Superimposed Loading Equations.
Beams of Uniform Cross Section, Loaded Transversely
Open
Beam Deflection and Stress Beams of Uniform Cross Section Calculator
Click on Images to view Large Readable Size
E = |
Beam Modulus of Elasticity | psi |
(N/mm2) |
I = |
Beam Moment of Inertia | in4 | (mm4) |
L = | Length of Beam | inches | (mm) |
F = |
Loading Point | lbs | (N) |
Mn = | Beam Moment Calculated | psi-in | (N-mm) |
WL = |
Distributed Load Amplitude | Lbs/in2 | (N/mm) |
Wa = |
y = |
Beam Deflection | inches | (mm) |
an
Some distance as indicated | inches | (mm) |
- Roark's Stress & Strain
- Beam Deflection Equations / Calculator Supported on Both Ends Uniform Loading
- Beam Deflection Equations / Calculator Supported on Both Ends Single Load at Center
- Beam Deflection Equations / Calculator Supported on Both Ends Loaded at any Location
- Beam Deflection Equations / Calculator Free and Guided on One End, Rigid one End With Uniform Load
- Beam Deflection Equations / Calculator Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Deflection Equations / Calculator Supported on Both Ends Loaded Two equal Loads
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
- Beam Deflection Equations / Calculator with End Overhanging Supports and a Single Load
- Beam Deflection Equations / Calculator Cantilevered Beam with One Load Applied at End
