Eckert Number Equation and Calculator
Heat Transfer Engineering
Thermodynamics
The Eckert number is dimensionless and is defined as the ratio of the advective mass transfer to the heat dissipation potential. The Eckert number provides a measure of the kinetic energy of the flow relative to the enthalpy difference across the thermal boundary layer. It is used to characterize heat dissipation in high-speed flows for which viscous dissipation is significant.
Ec = V2 / ( cp · ΔT )
ΔT = Tf - Ti
V = Characteristic Velocity of Flow (m/s)
cp = Constant-Pressure Specific Heat of Flow (m/s2 K)
ΔT = Temperature Difference (K)
Ti = Temperature intial (K)
Tf = Temperature final (K)
Ec = Eckert Number = Advective Transport/(Heat Dissipitation Potential) (dimensionless)
- Fundamentals of Heat and Mass Transfer, 7th Edition. Theodore L. Bergman, Adrienne S. Lavine, Frank P. Incropera. John Wiley & Sons, Incorporated, 2011. ISBN: 9781118137253.
- Heat and Mass Transfer. Yunus A. Cengel. McGraw-Hill Education, 2011. ISBN: 9780071077866.
- Grashof Number (GR) The Grashof number is used to determine the heat transfer coefficient under free convection conditions. It is basically a ratio between the buoyancy forces and viscous forces.
- Hemispherical Emissivities of Various Surfaces Table - emissivities of various surfaces at several wavelengths and temperatures.
- Heat Loss through a Double-Pane Window Equation and Calculator
- Conductive Heat Transfer Large Plane Equation and Calculator
- Conductive Heat Transfer of a Spherical Layer Equation and Calculator
- Heat Loss from a Pipe
- Heat Loss through a Insulated Pipe Equation and Calculator
- Convective Heat Transfer Coefficients Table Chart
- Emissivity of Surface Table
- Steady State Fenestration Heat Energy Flow and Loss
- Fourier's Law for Insulation Formula
