Estimated Fastener Bolt Clamp Force Torque Calculator
Fastener and Screw / Bolt Design Formula Design Data
Strength of Materials
Torque Force Design Equations
See Torque Force Design Equations webpage and torque chart page for recommended fastener torque and equation data. This calculator uses a practical starting point for all threaded fastener tightening analysis and uses the basic elastic torque-tension equation.
This fastener bolt torque calculator will Estimate the unknown torque, diameter, axial force applied and coefficient of turning friction for the given conditions. Minimum three (3) inputs are required then select "Find" button to get unknown
Similar resources
Instructions:
1) Enter known number values (two inputs minimum) within center located input boxes.
2) Select associated lower button to calculate unknown value.
3) This calculator may be used with any consistent units, e.g. torque = ft-lbs with ft, in-lbs with inches, N-mm with mm. Force is calculated consistent with units used.
Note: This calculator initially assumes dry and perfect threads made from steel and/or zinc plated. Calculated values are approximate. Calculated values do not compensate for materials stiffness.
Using this calculator:
Keep the units consistant, examples
torque (N-mm), fastener dia. (mm) and force (N)
torque (in-lbs), fastener dia. (in) and force (lbs)
torque (ft-lbs), fastener dia. (ft) and force (lbs)
Bolt Torque Force Design Equations
Torque Applied
(N-mm, in-lbs, ft-lbs)
Coefficient of Friction
Steel 0.2
Cadmium 0.16
Lubricated 0.16 - 0.17
Axial Bolt "Clamp" Force
(N, lbs, lbs)
www.engineersedge.com
Advertising | Contact
