Reinforced Concrete Sewer Pipe
ASTM C76 Reinforced Concrete Sewer Pipe Dimensions and Weights
ASTM C76– Reinforced Round Concrete Culvert, Storm Drain, and Sewer Pipe for Nonpressure (Gravity Flow) Applications
Nominal size
(internal diameter) |
Minimum wall thickness and maximum ASTM C76 D0.01-load rating
in and (lbf/ft2) |
in
mm
wall Aa
wall Ba
wall Ca
8b
200
2.0
10b
250
2.0
12
300
1.75 (2000)
2.0 (3000)
2.75 (3000)
15
375
1.875 (2000)
2.25 (3000)
3.0 (3000)
18
450
2.0 (2000)
2.5 (3000)
3.25 (3000)
21
525
2.25 (2000)
2.75 (3000)
3.50 (3000)
24
600
2.5 (2000)
3.0 (3000)
3.75 (3000)
27
675
2.625 (2000)
3.25 (3000)
4.0 (3000)
30
750
2.75 (2000)
3.5 (3000)
4.25 (3000)
33
825
2.875 (1350)
3.75 (3000)
4.5 (3000)
36
900
3.0 (1350)
4.0 (3000)
4.75 (3000)
42
1050
3.5 (1350)
4.5 (3000)
5.25 (3000)
48
1200
4.0 (1350)
5.0 (3000)
5.75 (3000)
54
1350
4.5 (1350)
5.5 (2000)
6.25 (3000)
60
1500
5.0 (1350)
6.0 (2000)
6.75 (3000)
66
1650
5.5 (1350)
6.5 (2000)
7.25 (3000)
72
1800
6.0 (1350)
7.0 (2000)
7.75 (3000)
78
1950
6.5 (1350)
7.5 (1350)
8.25 (2000)
84
2100
7.0 (1350)
8.0 (1350)
8.75 (1350)
90
2250
7.5 (1350)
8.5 (1350)
9.25 (1350)
96
2400
8.0 (1350)
9.0 (1350)
9.75 (1350)
102
2550
8.5 (1350)
9.5 (1350)
10.25 (1350)
108
2700
9.0 (1350)
10.0 (1350)
10.75 (1350)
(Multiply in by 25.4 to obtain mm.)
(Multiply lbf/ft2 by 0.04788 to obtain kN/m2 (kPa).)
awall A thickness in inches = diameter in feet; wall B thickness in inches = diameter in feet + 1 in; wall C thickness in inches = diameter
bAlthough not specifically called out in ASTM C76, 8 in and 10 in diameter circular concrete pipes are routinely manufactured.
Reference
ASTM C76: Reinforced Round Concrete Culvert, Storm Drain, and Sewer Pipe for Nonpressure (Gravity Flow) Applications
- ASTM C14 Concrete Sewer Pipe Dimensions and Weights
- Pipe Roughness Coefficients Table Charts | Hazen-Williams Coefficient | Manning Factor
- Pressure Drop Along Pipe Length - Fluid Flow Hydraulic and Pneumatic
- Storm Drain Pipe Size Requirement Formula and Calculator
- Standard Pipe Schedules and Sizes Chart Table Data
- Dn Diametre Nominel per ISO vs NPS Nominal Pipe Size
- Schedule 40 Plastic PVC, CPVC and Other Pipe Sizes and Dimensions | Schedule 40 Pipe
- Metric Pipe Sizes Dn vs NPS
- Gravity Sewer Pipe Dimensions and Sizes
- Pex (Cross-Linked Polyethylene) Specifications
- Xtra Strong (XS) Size Steel Pipe Weights Table Calculator
- Schedule 80 Steel Pipe Sizes and Dimensions ANSI
- Concrete Modulus of Rupture Equations and Calculator
- Manual of Concrete Design ACI
