Related Resources: fluid flow
Ductile Iron Pipe Sizes and Dimensions
Dimensions of Ductile Iron Pipe Special Pressure Classes (customary U.S. units)
Iron Pipe per. ANSI/AWWA C150/A21.50 and ANSI/AWWA C151/A21.51
Nominal sizea
(in) |
Outside
Diameter (in) |
Minimum wall thickness (in)
special pressure classb |
50
51
52
53
54
55
56
4
4.80
0.26
0.29
0.32
0.35
0.38
0.41
6
6.90
0.25
0.28
0.31
0.34
0.37
0.40
0.43
8
9.05
0.27
0.30
0.33
0.36
0.39
0.42
0.45
10
11.10
0.29
0.32
0.35
0.38
0.41
0.44
0.47
12
13.20
0.31
0.34
0.37
0.40
0.43
0.46
0.49
14
15.30
0.33
0.36
0.39
0.42
0.45
0.48
0.51
16
17.40
0.34
0.37
0.40
0.43
0.46
0.49
0.52
18
19.50
0.35
0.38
0.41
0.44
0.47
0.50
0.53
20
21.60
0.36
0.39
0.42
0.45
0.48
0.51
0.54
24
25.80
0.38
0.41
0.44
0.47
0.50
0.53
0.56
30
32.00
0.39
0.43
0.47
0.51
0.55
0.59
0.63
36
38.30
0.43
0.48
0.53
0.58
0.63
0.68
0.73
36
38.30
0.43
0.48
0.53
0.58
0.63
0.68
0.73
48
50.80
0.51
0.58
0.65
0.72
0.79
0.86
0.93
54
57.56
0.57
0.65
0.73
0.81
0.89
0.97
1.05
(Multiply in by 25.4 to obtain mm.)
(Multiply lbf/in2 by 6.895 to obtain kPa.)
aFormerly designated “standard thickness classes.” These special pressure classes are as shown in AWWA C150 and C151. Special classes are most appropriate for some threaded, grooved, or ball and socket pipes, or for extraordinary design conditions. They are generally less available than standard pressure class pipe.
b60 in (1500 mm) and 64 in (1600 mm) pipe sizes are not available in special pressure classes.
Reference
- Storm Drain Pipe Size Requirement Formula and Calculator
- Standard Pipe Schedules and Sizes Chart Table Data
- Pipe Thread Tap and Drill Size Chart ANSI NPT
- ASTM C14 Concrete Sewer Pipe Dimensions and Weights
- Copper Tubing Size Chart ASTM B-88
- Copper Tubing HVAC Size Chart
- Pex (Cross-Linked Polyethylene) Specifications
- Pipe Roughness Coefficients Table Charts | Hazen-Williams Coefficient | Manning Factor
- Pressure Drop Along Pipe Length - Fluid Flow Hydraulic and Pneumatic
- Dn Diametre Nominel per ISO vs NPS Nominal Pipe Size
- Schedule 40 Plastic PVC, CPVC and Other Pipe Sizes and Dimensions | Schedule 40 Pipe
- Metric Pipe Sizes Dn vs NPS
