ASTM A36 Structural Steel Angle Section Properties Table Chart
Structural Materials Menu
Engineering Materials Menu
ASTM Steel Angle Section Properties various sizes ranging L3 - L21
ASTM A36 angle is one of the most widely used carbon steels in industry. A36 steel it is weldable, formable, and machinable. Galvanizing the steel increases its corrosion-resistance.
The following chart table gives cross section engineering data for ASTM Structural Steel Angle as follows:
- Weight per foot
- Cross Section Area
- Area Moment of Inertia
- Wall Thickness
Related Resources:
- AISC, ASTM Angle Unequal Leg ( Aluminum )
- AISC, ASTM Angle Equal Leg ( Aluminum )
- AISC, ASTM Angle Unequal Leg ( Steel )
- Structural Steel Angle Section Properties, Unequal Leg BSI BS EN 10056
- Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
(d x bw x t) (in x in x in) |
lb/ft | Area (in2) | Ixx (in4) | yb (in) | Iyy (in4) | xb (in) |
L7x4x3/4 | 26.2 | 7.69 | 37.8 | 2.51 | 9.05 | 1.01 |
L7x4x5/8 | 22.1 | 6.48 | 32.4 | 2.46 | 7.84 | 0.963 |
L7x4x1/2 | 17.9 | 5.25 | 26.7 | 2.42 | 6.53 | 0.917 |
L7x4x3/8 | 13.6 | 3.98 | 20.6 | 2.37 | 5.1 | 0.87 |
L6x4x7/8 | 27.2 | 7.98 | 27.7 | 2.12 | 9.75 | 1.12 |
L6x4x3/4 | 23.6 | 6.94 | 24.5 | 2.08 | 8.68 | 1.08 |
L6x4x5/8 | 20 | 5.86 | 21.1 | 2.03 | 7.52 | 1.03 |
L6x4x9/16 | 18.1 | 5.31 | 19.3 | 2.01 | 6.91 | 1.01 |
L6x4x1/2 | 16.2 | 4.75 | 17.4 | 1.99 | 6.27 | 0.987 |
L6x4x7/16 | 14.3 | 4.18 | 15.5 | 1.96 | 5.6 | 0.964 |
L6x4x3/8 | 12.3 | 3.61 | 13.5 | 1.94 | 4.9 | 0.941 |
L6x4x5/16 | 10.3 | 3.03 | 11.4 | 1.92 | 4.18 | 0.918 |
L6x31/2x1/2 | 15.3 | 4.5 | 16.6 | 2.08 | 4.25 | 0.833 |
L6x31/2x3/8 | 11.7 | 3.42 | 12.9 | 2.04 | 3.34 | 0.787 |
L6x31/2x5/16 | 9.8 | 2.87 | 10.9 | 2.01 | 2.85 | 0.763 |
L5x31/2x5/8 | 16.8 | 4.92 | 12 | 1.7 | 4.83 | 0.951 |
L5x31/2x1/2 | 13.6 | 4 | 9.99 | 1.66 | 4.05 | 0.906 |
L5x31/2x7/16 | 12 | 3.53 | 8.9 | 1.63 | 3.63 | 0.883 |
L5x31/2x3/8 | 10.4 | 3.05 | 7.78 | 1.61 | 3.18 | 0.861 |
L5x31/2x5/16 | 8.7 | 2.56 | 6.6 | 1.59 | 2.72 | 0.838 |
L5x31/2x1/4 | 7 | 2.06 | 5.39 | 1.56 | 2.23 | 0.814 |
L5x3x5/8 | 15.7 | 4.61 | 11.4 | 1.8 | 3.06 | 0.796 |
L5x3x1/2 | 12.8 | 3.75 | 9.45 | 1.75 | 2.58 | 0.75 |
L5x3x7/16 | 11.3 | 3.31 | 8.43 | 1.73 | 2.32 | 0.727 |
L5x3x3/8 | 9.8 | 2.86 | 7.37 | 1.7 | 2.04 | 0.704 |
L5x3x5/16 | 8.2 | 2.4 | 6.26 | 1.68 | 1.75 | 0.681 |
L5x3x1/4 | 6.6 | 1.94 | 5.11 | 1.66 | 1.44 | 0.657 |
L4x31/2x1/2 | 11.9 | 3.5 | 5.32 | 1.25 | 3.79 | 1 |
L4x31/2x7/16 | 10.6 | 3.09 | 4.76 | 1.23 | 3.4 | 0.978 |
L4x31/2x3/8 | 9.1 | 2.67 | 4.18 | 1.21 | 2.95 | 0.955 |
L4x31/2x5/16 | 7.7 | 2.25 | 3.56 | 1.18 | 2.55 | 0.932 |
L4x31/2x1/4 | 6.2 | 1.81 | 2.91 | 1.16 | 2.09 | 0.909 |
L4x3x5/8 | 13.6 | 3.98 | 6.03 | 1.37 | 2.87 | 0.871 |
L4x3x1/2 | 11.1 | 3.25 | 5.05 | 1.33 | 2.42 | 0.827 |
L4x3x7/16 | 9.8 | 2.87 | 4.52 | 1.3 | 2.18 | 0.804 |
L4x3x3/8 | 8.5 | 2.48 | 3.96 | 1.28 | 1.92 | 0.782 |
L4x3x5/16 | 7.2 | 2.09 | 3.38 | 1.26 | 1.65 | 0.759 |
L4x3x1/4 | 5.8 | 1.69 | 2.77 | 1.24 | 1.36 | 0.736 |
L31/2x3x1/2 | 10.2 | 3 | 3.45 | 1.13 | 2.33 | 0.875 |
L31/2x3x7/16 | 9.1 | 2.65 | 3.1 | 1.1 | 2.09 | 0.853 |
L31/2x3x3/8 | 7.9 | 2.3 | 2.72 | 1.08 | 1.85 | 0.83 |
L31/2x3x5/16 | 6.6 | 1.93 | 2.33 | 1.06 | 1.58 | 0.808 |
L31/2x3x1/4 | 5.4 | 1.56 | 1.91 | 1.04 | 1.3 | 0.785 |
L31/2x21/2x1/2 | 9.4 | 2.75 | 3.24 | 1.2 | 1.36 | 0.705 |
L31/2x21/2x7/16 | 8.3 | 2.43 | 2.91 | 1.18 | 1.23 | 0.682 |
L31/2x21/2x3/8 | 7.2 | 2.11 | 2.56 | 1.16 | 1.09 | 0.66 |
L31/2x21/2x5/16 | 6.1 | 1.78 | 2.19 | 1.14 | 0.939 | 0.637 |
L31/2x21/2x1/4 | 4.9 | 1.44 | 1.8 | 1.11 | 0.777 | 0.614 |
L3x21/2x1/2 | 8.5 | 2.5 | 2.08 | 1 | 1.3 | 0.75 |
L3x21/2x7/16 | 7.6 | 2.21 | 1.88 | 0.978 | 1.18 | 0.728 |
L3x21/2x3/8 | 6.6 | 1.92 | 1.66 | 0.956 | 1.04 | 0.706 |
L3x21/2x5/16 | 5.6 | 1.62 | 1.42 | 0.933 | 0.898 | 0.683 |
L3x21/2x1/4 | 4.5 | 1.31 | 1.17 | 0.911 | 0.743 | 0.661 |
L3x21/2x3/16 | 3.39 | 0.996 | 0.907 | 0.888 | 0.577 | 0.638 |
L3x2x1/2 | 7.7 | 2.25 | 1.92 | 1.08 | 0.672 | 0.583 |
L3x2x7/16 | 6.8 | 2 | 1.73 | 1.06 | 0.609 | 0.561 |
L3x2x3/8 | 5.9 | 1.73 | 1.53 | 1.04 | 0.543 | 0.539 |
L3x2x5/16 | 5 | 1.46 | 1.32 | 1.02 | 0.47 | 0.516 |
L3x2x1/4 | 4.1 | 1.19 | 1.09 | 0.993 | 0.392 | 0.493 |
L3x2x3/16 | 3.07 | 0.902 | 0.842 | 0.97 | 0.307 | 0.47 |
L21/2x2x3/8 | 5.3 | 1.55 | 0.912 | 0.831 | 0.514 | 0.581 |
L21/2x2x5/16 | 4.5 | 1.31 | 0.788 | 0.809 | 0.446 | 0.559 |
L21/2x2x1/4 | 3.62 | 1.06 | 0.654 | 0.787 | 0.372 | 0.537 |
L21/2x2x3/16 | 2.75 | 0.809 | 0.509 | 0.764 | 0.291 | 0.514 |
