ASTM B308 Aluminum Structural Shape Angle Unequal Legs
Structural Angle Aluminum Unequal Legs - The table below gives the size and shape dimensions, weight per foot and cross section area for aluminum angle per ASTM.
Size Leg1 X Leg2 X Thickness |
Weight (lb/Ft) |
Area (in2) |
1.50 x 1.25 x 0.125 |
.386 |
.329 |
1.50 x 1.25 x 0.188 |
.566 | .481 |
1.75 x 1.25 x 0.125 |
.423 |
.36 |
2.00 x 1.50 x 0.125 |
.497 | .423 |
2.00 x 1.50 x 0.188 |
.731 |
.622 |
2.00 x 1.50 x 0.250 |
.956 |
.813 |
2.50 x 1.50 x 0.188 |
.848 |
.721 |
2.50 x 2.00 x 0.188 |
.959 |
.815 |
2.50 x 2.00 x 0.250 |
1.257 |
1.069 |
3.00 x 1.50 x 0.250 |
1.266 |
1.077 |
3.00 x 2.00 x 0.188 |
1.068 |
.908 |
3.00 x 2.00 x 0.250 |
1.403 |
1.193 |
3.00 x 2.00 x 0.375 |
2.047 |
1.74 |
3.00 x 2.50 x 0.250 |
1.55 |
1.318 |
3.50 x 2.50 x 0.250 |
1.684 |
1.432 |
4.00 x 3.00 x 0.250 |
1.988 |
1.691 |
4.00 x 3.00 x 0.375 |
2.926 |
2.488 |
5.00 x 3.00 x 0.250 |
2.265 |
1.926 |
5.00 x 3.00 x 0.375 |
3.349 |
2.848 |
5.00 x 3.50 x 0.500 |
4.703 |
3.999 |
6.00 x 4.00 x 0.375 |
4.237 |
3.603 |
6.00 x 4.00 x 0.500 |
5.578 |
4.743 |
Related Resources:
- AISC Ultimate Structural Shapes Properties Viewer
- AISC, ASTM Angle Equal Leg
- AISC, ASTM Channel, Standard
- AISC, ASTM Channel (Steel)
- AISC, ASTM Wide Flange #1 (Steel)
- AISC, ASTM Wide Flange #2 (Steel)
- AISC, ASTM S Flange (Steel)
- AISC, ASTM Angle (Steel)
- AISC, ASTM Angle Unequal Leg
- AISC, ASTM I-Beams
- AISC, ASTM Structural Tees Cut from W Flange
