Structural A36 Steel Wide Flange I Beam Section Properties Table
Structural Materials Menu
Engineering Materials Menu
ASTM Steel Wide Channel H Beam Section Properties various sizes ranging W14 - W25
ASTM A36 Wide Channel H Beam is one of the most widely used carbon steels in industry. A36 steel it is weldable, formable, and machinable. Galvanizing the steel increases its corrosion-resistance.
- Weight per foot
- Cross Section Area
- Area Moment of Inertia
- Wall Thickness
Related Resources:
- AISC, ASTM Angle Unequal Leg ( Aluminum )
- AISC, ASTM Angle Equal Leg ( Aluminum )
- AISC, ASTM Angle Unequal Leg ( Steel )
- Structural Steel Angle Section Properties, Unequal Leg BSI BS EN 10056
- Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
The following chart table gives cross section engineering data for ASTM Structural Steel Wid Channel I Beam as follows:
in × lb/ft | Area (in2) | d (in) | bf (in) | tf (in) | tw (in) | Ixx (in4) | Iyy (in4) |
W27x178 | 52.3 | 27.81 | 14.085 | 1.19 | 0.725 | 6990 | 555 |
W27x161 | 47.4 | 27.59 | 14.02 | 1.08 | 0.66 | 6280 | 497 |
W27x146 | 42.9 | 27.38 | 13.965 | 0.975 | 0.605 | 5630 | 443 |
W27x114 | 33.5 | 27.29 | 10.07 | 0.93 | 0.57 | 4090 | 159 |
W27x102 | 30 | 27.09 | 10.015 | 0.83 | 0.515 | 3620 | 139 |
W27x94 | 27.7 | 26.92 | 9.99 | 0.745 | 0.49 | 3270 | 124 |
W27x84 | 24.8 | 26.71 | 9.96 | 0.64 | 0.46 | 2850 | 106 |
W24x162 | 47.7 | 25 | 12.955 | 1.22 | 0.705 | 5170 | 443 |
W24x146 | 43 | 24.74 | 12.9 | 1.09 | 0.65 | 4580 | 391 |
W24x131 | 38.5 | 24.48 | 12.855 | 0.96 | 0.605 | 4020 | 340 |
W24x117 | 34.4 | 24.26 | 12.8 | 0.85 | 0.55 | 3540 | 297 |
W24x104 | 30.6 | 24.06 | 12.75 | 0.75 | 0.5 | 3100 | 259 |
W24x94 | 27.7 | 24.31 | 9.065 | 0.875 | 0.515 | 2700 | 109 |
W24x84 | 24.7 | 24.1 | 9.02 | 0.77 | 0.47 | 2370 | 94.4 |
W24x76 | 22.4 | 23.92 | 8.99 | 0.68 | 0.44 | 2100 | 82.5 |
W24x68 | 20.1 | 23.73 | 8.965 | 0.585 | 0.415 | 1830 | 70.4 |
W24x62 | 18.2 | 23.74 | 7.04 | 0.59 | 0.43 | 1550 | 34.5 |
W24x55 | 16.2 | 23.57 | 7.005 | 0.505 | 0.395 | 1350 | 29.1 |
W21x147 | 43.2 | 22.06 | 12.51 | 1.15 | 0.72 | 3630 | 376 |
W21x132 | 38.8 | 21.83 | 12.44 | 1.035 | 0.65 | 3220 | 333 |
W21x122 | 35.9 | 21.68 | 12.39 | 0.96 | 0.6 | 2960 | 305 |
W21x111 | 32.7 | 21.51 | 12.34 | 0.875 | 0.55 | 2670 | 274 |
W21x101 | 29.8 | 21.36 | 12.29 | 0.8 | 0.5 | 2420 | 248 |
W21x93 | 27.3 | 21.62 | 8.42 | 0.93 | 0.58 | 2070 | 92.9 |
W21x83 | 24.3 | 21.43 | 8.355 | 0.835 | 0.515 | 1830 | 81.4 |
W21x73 | 21.5 | 21.24 | 8.295 | 0.74 | 0.455 | 1600 | 70.6 |
W21x68 | 20 | 21.13 | 8.27 | 0.685 | 0.43 | 1480 | 64.7 |
W21x62 | 18.3 | 20.99 | 8.24 | 0.615 | 0.4 | 1330 | 57.5 |
W21x57 | 16.7 | 21.06 | 6.555 | 0.65 | 0.405 | 1170 | 30.6 |
W21x50 | 14.7 | 20.83 | 6.53 | 0.535 | 0.38 | 984 | 24.9 |
W21x44 | 13 | 20.66 | 6.5 | 0.45 | 0.35 | 843 | 20.7 |
W18x119 | 35.1 | 18.97 | 11.265 | 1.06 | 0.655 | 2190 | 253 |
W18x106 | 31.1 | 18.73 | 11.2 | 0.94 | 0.59 | 1910 | 220 |
W18x97 | 28.5 | 18.59 | 11.145 | 0.87 | 0.535 | 1750 | 201 |
W18x86 | 25.3 | 18.39 | 11.09 | 0.77 | 0.48 | 1530 | 175 |
W18x76 | 22.3 | 18.21 | 11.035 | 0.68 | 0.425 | 1330 | 152 |
W18x71 | 20.8 | 18.47 | 7.635 | 0.81 | 0.495 | 1170 | 60.3 |
W18x65 | 19.1 | 18.35 | 7.59 | 0.75 | 0.45 | 1070 | 54.8 |
W18x60 | 17.6 | 18.24 | 7.555 | 0.695 | 0.415 | 984 | 50.1 |
W18x55 | 16.2 | 18.11 | 7.53 | 0.63 | 0.39 | 890 | 44.9 |
W18x50 | 14.7 | 17.99 | 7.495 | 0.57 | 0.355 | 800 | 40.1 |
W18x46 | 13.5 | 18.06 | 6.06 | 0.605 | 0.36 | 712 | 22.5 |
W18x40 | 11.8 | 17.9 | 6.015 | 0.525 | 0.315 | 612 | 19.1 |
W18x35 | 10.3 | 17.7 | 6 | 0.425 | 0.3 | 510 | 15.3 |
W16x100 | 29.4 | 16.97 | 10.425 | 0.985 | 0.585 | 1490 | 186 |
W16x89 | 26.2 | 16.75 | 10.365 | 0.875 | 0.525 | 1300 | 163 |
W16x77 | 22.6 | 16.52 | 10.295 | 0.76 | 0.455 | 1110 | 138 |
W16x67 | 19.7 | 16.33 | 10.235 | 0.665 | 0.395 | 954 | 119 |
W16x57 | 16.8 | 16.43 | 7.12 | 0.715 | 0.43 | 758 | 43.1 |
W16x50 | 14.7 | 16.26 | 7.07 | 0.63 | 0.38 | 659 | 37.2 |
W16x45 | 13.3 | 16.13 | 7.035 | 0.565 | 0.345 | 586 | 32.8 |
W16x40 | 11.8 | 16.01 | 6.995 | 0.505 | 0.305 | 518 | 28.9 |
W16x36 | 10.6 | 15.86 | 6.985 | 0.43 | 0.295 | 448 | 24.5 |
W16x31 | 9.12 | 15.88 | 5.525 | 0.44 | 0.275 | 375 | 12.4 |
W16x26 | 7.68 | 15.69 | 5.5 | 0.345 | 0.25 | 301 | 9.59 |
W14x665 | 196 | 21.64 | 17.65 | 4.52 | 2.83 | 12400 | 4170 |
W14x605 | 178 | 20.92 | 17.415 | 4.16 | 2.595 | 10800 | 3680 |
W14x550 | 162 | 20.24 | 17.2 | 3.82 | 2.38 | 9430 | 3250 |
W14x500 | 147 | 19.6 | 17.01 | 3.5 | 2.19 | 8210 | 2880 |
W14x455 | 134 | 19.02 | 16.835 | 3.21 | 2.015 | 7190 | 2560 |
W14x426 | 125 | 18.67 | 16.695 | 3.035 | 1.875 | 6600 | 2360 |
W14x398 | 117 | 18.29 | 16.59 | 2.845 | 1.77 | 6000 | 2170 |
W14x370 | 109 | 17.92 | 16.475 | 2.66 | 1.655 | 5440 | 1990 |
W14x342 | 101 | 17.54 | 16.36 | 2.47 | 1.54 | 4900 | 1810 |
W14x311 | 91.4 | 17.12 | 16.23 | 2.26 | 1.41 | 4330 | 1610 |
W14x283 | 83.3 | 16.74 | 16.11 | 2.07 | 1.29 | 3840 | 1440 |
W14x257 | 75.6 | 16.38 | 15.995 | 1.89 | 1.175 | 3400 | 1290 |
W14x233 | 68.5 | 16.04 | 15.89 | 1.72 | 1.07 | 3010 | 1150 |
W14x211 | 62 | 15.72 | 15.8 | 1.56 | 0.98 | 2660 | 1030 |
W14x193 | 56.8 | 15.48 | 15.71 | 1.44 | 0.89 | 2400 | 931 |
W14x176 | 51.8 | 15.22 | 15.65 | 1.31 | 0.83 | 2140 | 838 |
W14x159 | 46.7 | 14.98 | 15.565 | 1.19 | 0.745 | 1900 | 748 |
W14x145 | 42.7 | 14.78 | 15.5 | 1.09 | 0.68 | 1710 | 677 |
W14xI32 | 38.8 | 14.66 | 14.725 | 1.03 | 0.645 | 1530 | 548 |
W14x120 | 35.3 | 14.48 | 14.67 | 0.94 | 0.59 | 1380 | 495 |
W14x109 | 32 | 14.32 | 14.605 | 0.86 | 0.525 | 1240 | 447 |
W14x99 | 29.1 | 14.16 | 14.565 | 0.78 | 0.485 | 1110 | 402 |
W14x90 | 26.5 | 14.02 | 14.52 | 0.71 | 0.44 | 999 | 362 |
W14x82 | 24.1 | 14.31 | 10.13 | 0.855 | 0.51 | 882 | 148 |
W14x74 | 21.8 | 14.17 | 10.07 | 0.785 | 0.45 | 796 | 134 |
W14x68 | 20 | 14.04 | 10.035 | 0.72 | 0.415 | 723 | 121 |
W14x61 | 17.9 | 13.89 | 9.995 | 0.645 | 0.375 | 640 | 107 |
W14x53 | 15.6 | 13.92 | 8.06 | 0.66 | 0.37 | 541 | 57.7 |
W14x48 | 14.1 | 13.79 | 8.03 | 0.595 | 0.34 | 485 | 51.4 |
W14x43 | 12.6 | 13.66 | 7.995 | 0.53 | 0.305 | 428 | 45.2 |
W14x38 | 11.2 | 14.1 | 6.77 | 0.515 | 0.31 | 385 | 26.7 |
W14x34 | 10 | 13.98 | 6.745 | 0.455 | 0.285 | 340 | 23.3 |
W14x30 | 8.85 | 13.84 | 6.73 | 0.385 | 0.27 | 291 | 19.6 |
W14x26 | 7.69 | 13.91 | 5.025 | 0.42 | 0.255 | 245 | 8.91 |
W14x22 | 6.49 | 13.74 | 5 | 0.335 | 0.23 | 199 | 7 |
