Beam Deflection and Stress Equations Calculator for Beam Supported on One End, Rigid one End With Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Supported on One End, Rigid one End With Uniform Load.
Open
Beam Supported One End, Rigid End With Uniform Load Calculator
Beam Stress at Any Point
Beam Stress at the fixed support
Beam Deflection at specified point
Beam Deflection at the center
E = Modulus of Elasticity psi
(N/mm2)
W = Beam  Load lbs (N)
s =  Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition, Page 410 or,
  • Machinery's Handbook, 23st Edition, Page 266 or,
  • Machinery's Handbook, 27st Edition, Page 267
