Beam Deflection and Stress Equations and Calculator Beam Uniform Loading
Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Uniform loading Applied
Figure 1
Reaction and Shear Equation
Bending Moments Equation
E = | Modulus of Elasticity | psi |
I = | Area Moment of Inertia | in4 |
W = | Load, Total | lbf |
w = | Unit Load | lbs/in |
yx = | Deflection at x ≤ L | inches |
yx1 = | Deflection at x1 ≤ a | inches |
M1, = | Moment @ formula calc'd distance x | lbs-in |
MB, = | Moment @ B | lbs-in |
Mx = | Moment @ distance x | lbs-in |
Mx1 = | Moment @ distance x1 ≤ a | lbs-in |
a, b, c, d, x, L = | Some distance as indicated | inches |
RA = | Reaction force at support A | lbf |
RB = | Reaction force at support B | lbf |
V1 = | Shear Load see Figure 1 | lbf |
V2 = | Shear Load see Figure 1 | lbf |
Vx = | Shear Load see Figure 1 | lbf |
Vx1 = | Shear Load see Figure 1 | lbf |
θA = | Slope Angle @ x = 0 | Rad |
θx = | Slope Angle | Rad |
θB = | Slope Angle @ x1 = 0 | Rad |
θC = | Slope Angle @ see equation | Rad |
θx1 = | Slope Angle | Rad |
- Boeing Design Manual, Rev G. 1994 BDM
- 2D CAD Static's Modeler and Loads Calculator
- AISC Steel structural Shapes Property Viewer
- Beam Stress Deflection Equations / Calculation - Fixed at One End, Supported at the Other, Load at any Point
- Beam Stress Deflection Equations / Calculation - Fixed at Both Ends, Load at Center
- Beam Stress Deflection Equations / Calculation - Fixed at Both Ends, Load at any Location
- Beam Stress Deflection Equations / Calculation with Uniform Loading
- Beam Bending Stress Deflection Equations / Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads
- Beam Stress Deflection Equations / Calculation - Continuous Beam, with Two Equal Spans, Uniform Load
- Beam Stress Defection Simply Supported on Both Ends Under Superimposed Loading Equations
- Bearing Stress Between Angled Strut and Supporting Pin Equations and Calculator
- Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
- Beam Bending Equations / Calculation Cantilevered Beam with One Load Applied at End
