Beam Deflection Free and Guided on One End, Rigid one End With Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Beam Free and Guided on One End, Rigid one End With Uniform Load.
Open
Beam Free and Guided on One End Stress and Deflections Calculator
Beam Stress at Any Point
Beam Stress at the fixed support
Beam Deflection at specified point
Beam Deflection at the free end
W = | Load | lbs | (N) |
s = | Beam Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
l = | Some distance as indicated | inches | (mm) |
Z = |
z = |
- Please note letter "l" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 410 or,
- Machinery's Handbook, 23st Edition, Page 266 or,
- Machinery's Handbook, 27st Edition, Page 267
- Beam Stress Defection Simply Supported on Both Ends Under Superimposed Loading Equations
- Bearing Stress Between Angled Strut and Supporting Pin Equations and Calculator
- Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Partial Distributed Load
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Tapered Load
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Reversed Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limited Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Reversed Limited Tapered Load
- Beam Supported One End, Pin Opposite End and Partial Distributed Load Deflection, Shear and Stress Equations and Calculator
- Beam Deflection and Stress Equations / Calculator Cantilevered Beam with One Load Applied at End
