Beam Deflection Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load.
Beam Bending Moments Equation
Stress Maximum
E = Modulus of Elasticity psi
(N/mm2)
W = Beam Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
e = Centroid inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
θmax = Beam Slope Angle degree (radian)
σmax = Beam Stress max. psi (N/mm2)
  • Beam Deflections apply only to constant cross sections along entire length.
