Beam Deflection Calculator and Stress Equations for Continuous Beam, with Two Equal Spans, Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Continuous Beam, with Two Equal Spans, Uniform Load.
Continuous Beam Delfections, with Two Equal Spans, Uniform Load
Beam Section Modulus Z
Z = I/c
I = Moment of inertia Cross Section : Units in4 (m4)
z = Distance neutral axis to extreme fiber: Units in (m)
General Beam Stress at any Given Point
General Stress at any Given Point
Open: General Stress at any Given Point Calculator
Beam Deflection at any Point
Open: Deflection any Given Point Calculator
Critical Beam Deflections
Critical Deflections
E = Modulus of Elasticity psi
(N/mm2)
W =  Beam Load lbs (N)
s =  Beam Stress at the cross-section being evaluated Lbs/in2 (N/mm2)
u = Some distance as indicated inches (mm)
a, b = Some distance as indicated inches (mm)
L = Some distance as indicated inches (mm)
l = Some distance as indicated inches (mm)
Z =
z =
  • Please note letter "l " (lower case "L") is different than "I" (Moment of Inertia).
  • Machinery's Handbook, 21st Edition
  • Machinery's Handbook, 23st Edition
  • Machinery's Handbook, 27st Edition
