Beam Deflection Equations and Calculator including Stress and Reaction Loads for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load.
Beam Bending Moments Equation
Beam Stress Maximum
W = | Load, Total | lbf | (N) |
w = | Beam Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Shear Load | lbf | (N) |
Mmax = | Beam Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Stress Deflection Moment Equations and Calculator Beam Supported Partial Tapering Load Applied Equation and Calculator
- Stress Deflection Strain Equations and Calculator Beam Supported Tapering Load Applied
- Stress Deflection Strain Moment Equations and Calculator Beam Supported Partial Tapering Load Applied
- Stresses in Three Dimensions Excel Spreadsheet Calculator
- Beam Stress & Deflection Equations / Calculator Free and Guided on One End
- Beam Stress & Deflection Equations / Calculator Moment Applied at Defined Location
- Beam Stress Deflection Equations / Calculator with Partial Uniform Loading
- Beam Stress Deflection Equations / Calculator with Partial Tapering Loading
- Beam Stress Deflection Equations / Calculator with Fixed Ends Tapering Loading
