Beam Deflection, Stress, Bending calculator for a Beam Fixed at Both Ends with Partial Uniform Loading
Beam Deflection, Stress, Strain Equations and Calculators
Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends with Partial Uniform Loading.
Preview Beam Deflection, Stress, Strain Calculator
Reaction and Shear Equation
Bending Moments Equation
Deflection Equation
E = Modulus of Elasticity psi
(N/mm2)
W = Load, Total lbf (N)
w = Unit Load lbs/in (N/mm)
y = Deflection inches (mm)
Vmax = Shear Load lbf (N)
Mmax = Moment lbs-in (N-mm)
