Beam Stress Calculator, Stress Bending Equations for a Beam Fixed at Both Ends with Partial Tapering Loading.
Beam Deflection, Stress, Strain Equations and Calculators
Beam Deflection, Stress, Bending Equations and calculator for a Beam Fixed at Both Ends with Partial Tapering Loading..
Reaction and Shear Equation
Bending Moments Equation
W = | Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
y = | Deflection | inches | (mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Shear Load | lbf | (N) |
Mmax = | Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Tapered Load
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Reversed Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limited Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Reversed Limited Tapered Load
- Beam Supported One End, Pin Opposite End and Partial Distributed Load Deflection, Shear and Stress Equations and Calculator
- Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated.
- Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
- Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
