Beam Stress Calculator with Deflection Equations for Fixed Ends Tapering Loading
Beam Deflection, Stress, Strain Equations and Calculators
Beam Stress Deflection Equations / Calculator with Fixed Ends Tapering Loading
Reaction and Shear Equation
Bending Moments Equation
W = | Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
y = | Deflection | inches | (mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Shear Load | lbf | (N) |
Mmax = | Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Two Tapered Distributed Load
- Flexural Strengthening of Reinforced Concrete Beam with FRP Laminates Spreadsheet Calculator
- Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
- Calculator for a Beam supported One End, Pin Opposite End and Single Moment at End Applied
- Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
- Stress Equations and Calculator for a Beam supported One End, One End, Cantilevered at Defined Location and Distributed Load Between Supports
- Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load Between Supports
- Stress Equations and Calculator for a Beam Supported One End, Cantilevered at Defined Location and Single Moment Applied at End
