Beam Deflection Equations including Stress for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
Shear, Deflection and Stress Equations and Calculator for a Beam supported One End, Cantilevered at Defined Location and Single Load at End
Beam Moments Equation
Beam Stress Maximum
W = | Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Beam Shear Load | lbf | (N) |
Mmax = | Beam Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Frame Deflection with Concentrated Load Applied to Vertical Member Equations and Calculator
- Frame Deflection with Distributed Load Applied to Left Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Moment Applied to Left Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Angular Displacement Applied to Left Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Lateral Displacement Applied to Left Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Load Applied to Right Vertical Member Equations and Calculator
- Frame Deflection with Distributed Load Applied to Right Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Moment Applied to Right Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Angular Displacement Applied Right Vertical Member Equations and Calculator
- Frame Deflection with Concentrated Lateral Displacement Applied Right Vertical Member Equations and Calculator
- Beam Deflection Calculator Cantilevered Beam with One Load Applied at End
