Beam Deflection Calculator, Shear and Stress Equations for a Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated.
Beam Deflection Moments Equation
Beam Stress Maximum
W = | Load, Total | lbf | (N) |
w = | Unit Load | lbs/in | (N/mm) |
yx = | Deflection | inches | (mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Shear Load | lbf | (N) |
Mmax = | Beam Beam Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
Ra,b = | Load | lbf | (N) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Stress Equations / Calculator - Both Ends Overhanging Supports, Load at any Point Between
- Structural Beam Bending Stress Deflection Equations / Calculation - Fixed at One End, Supported at the Other, Load at Center
- Beam Stress Deflection Equations / Calculator - Fixed at One End, Supported at the Other, Load at any Point
- Beam Stress Deflection Equations / Calculator - Fixed at Both Ends, Load at Center
- Beam Stress Deflection Equations / Calculator - Fixed at Both Ends, Load at any Location
- Beam Stress Deflection Equations / Calculator with Uniform Loading
- Beam Bending Stress Deflection Equations / Continuous Beam, with Two Unequal Spans, Unequal, Uniform Loads
