Beam Deflection and Stress Equations Calculator for Cantilevered Beam with Uniform Load
Structural Beam Deflection, Stress, Bending Equations and calculator for a Cantilevered Beam with Uniform Load.
Open
Beam Beam and Stress Cantilevered Beam with Uniform Load Calculator
Beam Stress at specific point
Beam Stress at the support (must be constant cross section)
Beam Deflection at specified point
Beam Deflection at the unsupported end, With Total load "W"
or
Beam Deflection at the unsupported end, With Line Pressure Load "p"
W = | Total Load on Beam (Not Line Load) | lbs | (N) |
p = | With Line Pressure Load | psi-in | (N/mm) |
s = | Stress at the cross-section being evaluated | Lbs/in2 | (N/mm2) |
Z = |
z = |
Length as indicated | inches | (mm) |
- Please note letter "" (lower case "L") is different than "I" (Moment of Inertia).
- Machinery's Handbook, 21st Edition, Page 407 or,
- Machinery's Handbook, 23st Edition, Page 263 or,
- Machinery's Handbook, 27st Edition, Page 264
- Beam Deflection, Shear and Stress Equations and calculator for a Beam supported One End Cantilevered with Reversed Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Limited Tapered Load
- Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End Cantilevered with Reversed Limited Tapered Load
- Beam Supported One End, Pin Opposite End and Partial Distributed Load Deflection, Shear and Stress Equations and Calculator
- Beam supported One End, Pin Opposite End and two Partial Distributed Load Separated.
- Brittle Failure Theories Computing Safety Factors Excel Spreadsheet Calculator
- Equations and Calculator for a Beam supported One End, Pin Opposite End and One Tapered Distributed Load
