Euler Number Equation and Calculator
The Euler number (Eu) is a dimensionless number used in fluid flow calculations. It expresses the relationship between a local pressure drop caused by a restriction and the kinetic energy per volume of the flow, and is used to characterize energy losses in the flow, where a perfect frictionless flow corresponds to an Euler number of 0. The inverse of the Euler number is referred to as the Ruark Number with the symbol Ru.
Eu = (Pu - Pd ) / ( ρ · v 2 )
Eu = Pressure forces / inertial forces
An alternative definition of the Euler number is given by Shah and Sekulic
Eu = (Pu - Pd ) / ( 0.5 · ρ · v 2 )
Eu = Pressure drop / dynamic head
ρ = Density of Fluid (kg/m3)
Pu = Upstream Pressure (kg/ms2)
Pd = Downstream Pressure (kg/ms2)
V = Velocity of Flow (m/s)
Eu = Euler Number (dimensionless)
- Wikipedia
- Air Leakage Rates for Typical Home Components
- Air Flow Drag and Drag Coefficient Equations and Calculator
- Mass Flow Rate for Gas Pipeline Blowdown through Hole or Orifice Excel Spreadsheet Calculator
- Fluid Flow Discharge Time under Falling Head Formula and Calculator
- Fluid Kinetic Force in Conduits Calculator and Equation
- Fluid Momentum Flux Equation and Calculator Momentum Flux is the rate of change of momentum flowing through unit area.
- Hydrostatic Pressure Force of a Fluid On Vessel Planes Equations The hydrostatic force of pressure F is that force which is exerted on the wall by the fluid only - i.e. without consideration of pressure p 0 .
- Head Loss at Pipe Abrupt Exit Equations and Calculator of a fluid.
- Head loss and head loss coefficient equation and calculator of a fluid in across a screen (circular metal wire mesh) inside a pipe.
- Steady-State Flow Steady-state flow refers to the condition where the fluid properties at any single point in the system do not change over time.
- Wind Mill Powered Piston Pumps Design Equation and Calculator
