Standard Mechanical Tolerance Table Charts for Shaft - Hole Fits
Mechanical Tolerance Standards Charts
The following links are to General Tolerance Table Charts for Standard Shaft Hole Fits per McDonald Douglas Design Guide "Machining Tolerances". The size ranges given are for typical size ranges utilized within industry.
For more industry standard tolerance data see: Mechanical Tolerance Standards Charts
Select "Class XX" based on required functional fit to access page.
Class I - Loose fit - Use for all possible hole - shaft applications where function will permit.
Class II - Free Fit - Running fits with speeds of 600 R.P.M. or over and journal pressures of 500 lbs/sqin or over. Wobble or shake between mating parts very slight. Part will turn and slide freely.
Class III - Medium Fit - Running fits under 600 R.P.M and journal pressures under 600 lbs/sqin and for sliding fits. Wobble or shake between mating parts noticed only on parts with short bearing length.
Class IV - Transitional Fit (Snug) - Closest fit which can be assembled by hand and necessitates work of considerable precision. Should be used where no perceptible shake is permissible and, where moving parts are not intended to move freely under a load.
Class V - Interference Fit - Considerable pressure is required to assemble these fits and the parts are considered more or less permanently assembled. Bushings and similar uses.
Note:
Material basis is steel. The coefficient of expansion of material considered should be checked against the basis temperature of 70 deg F .
Related Resources:
- Gage Tolerance Calculator ASME B89.1.5 Pin and Ring Gauges
- ISO Tolerances For Fasteners
- Gauge Blocks Tolerances Specifications Table DIN 861
- General Tolerances Shaft - Holes Fits
- GD&T Geometric Dimensioning Tolerancing Basics Training
- GD&T Geometric Dimensioning Tolerancing Intermediate Training
- GDT ASME Y14.5-2009 Applications Training
- G&T Geometric Tolerancing ISO 1101 Training
- Online GD&T Fundamentals Training
