ASTM A36 Structural Steel Angle Section Properties
Structural Materials Menu
Engineering Materials Menu
ASTM Steel Angle Section Properties various sizes ranging L2 - L31
ASTM A36 angle is one of the most widely used carbon steels in industry. A36 steel it is weldable, formable, and machinable. Galvanizing the steel increases its corrosion-resistance.
The following chart table gives cross section engineering data for ASTM Structural Steel Angle as follows:
- Weight per foot
- Cross Section Area
- Area Moment of Inertia
- Wall Thickness
Related Resources:
- AISC, ASTM Angle (Steel)
- AISC, ASTM Angle Unequal Leg ( Aluminum )
- AISC, ASTM Angle Equal Leg ( Aluminum )
- AISC, ASTM Angle Unequal Leg ( Steel )
- Structural Steel Angle Section Properties, Unequal Leg BSI BS EN 10056
- Structural Steel Angle Section Properties, Equal Leg BSI BS EN 10056
(d x bw x t) (in x in x in) |
lb/ft | Area (in2) | Ixx (in4) | yb (in) | Iyy (in4) | xb (in) |
L8x8x11/8 | 56.9 | 16.7 | 98 | 2.41 | 98 | 2.41 |
L8x8x1 | 51 | 15 | 89 | 2.37 | 89 | 2.37 |
L8x8x7/8 | 45 | 13.2 | 79.6 | 2.32 | 79.6 | 2.32 |
L8x8x3/4 | 38.9 | 11.4 | 69.7 | 2.28 | 69.7 | 2.28 |
L8x8x5/8 | 32.7 | 9.61 | 59.4 | 2.23 | 59.4 | 2.23 |
L8x8x9/16 | 29.6 | 8.68 | 54.1 | 2.21 | 54.1 | 2.21 |
L8x8x1/2 | 26.4 | 7.75 | 48.6 | 2.19 | 48.6 | 2.19 |
L6x6x1 | 37.4 | 11 | 35.5 | 1.86 | 35.5 | 1.86 |
L6x6x7/8 | 33.1 | 9.73 | 31.9 | 1.82 | 31.9 | 1.82 |
L6x6x3/4 | 28.7 | 8.44 | 28.2 | 1.78 | 28.2 | 1.78 |
L6x6x5/8 | 24.2 | 7.11 | 24.2 | 1.73 | 24.2 | 1.73 |
L6x6x9/16 | 21.9 | 6.43 | 22.1 | 1.71 | 22.1 | 1.71 |
L6x6x1/2 | 19.6 | 5.75 | 19.9 | 1.68 | 19.9 | 1.68 |
L6x6x7/16 | 17.2 | 5.06 | 17.7 | 1.66 | 17.7 | 1.66 |
L6x6x3/8 | 14.9 | 4.36 | 15.4 | 1.64 | 15.4 | 1.64 |
L6x6x5/16 | 12.4 | 3.65 | 13 | 1.62 | 13 | 1.62 |
L5x5x7/8 | 27.2 | 7.98 | 17.8 | 1.57 | 17.8 | 1.57 |
L5x5x3/4 | 23.6 | 6.94 | 15.7 | 1.52 | 15.7 | 1.52 |
L5x5x5/8 | 20 | 5.86 | 13.6 | 1.48 | 13.6 | 1.48 |
L5x5x1/2 | 16.2 | 4.75 | 11.3 | 1.43 | 11.3 | 1.43 |
L5x5x7/16 | 14.3 | 4.18 | 10 | 1.41 | 10 | 1.41 |
L5x5x3/8 | 12.3 | 3.61 | 8.74 | 1.39 | 8.74 | 1.39 |
L5x5x5/16 | 10.3 | 3.03 | 7.42 | 1.37 | 7.42 | 1.37 |
L4x4x3/4 | 18.5 | 5.44 | 7.67 | 1.27 | 7.67 | 1.27 |
L4x4x5/8 | 15.7 | 4.61 | 6.66 | 1.23 | 6.66 | 1.23 |
L4x4x1/2 | 12.8 | 3.75 | 5.56 | 1.18 | 5.56 | 1.18 |
L4x4x7/16 | 11.3 | 3.31 | 4.97 | 1.16 | 4.97 | 1.16 |
L4x4x3/8 | 9.8 | 2.86 | 4.36 | 1.14 | 4.36 | 1.14 |
L4x4x5/16 | 8.2 | 2.4 | 3.71 | 1.12 | 3.71 | 1.12 |
L4x4x1/4 | 6.6 | 1.94 | 3.04 | 1.09 | 3.04 | 1.09 |
L31/2x31/2x1/2 | 11.1 | 3.25 | 3.64 | 1.06 | 3.64 | 1.06 |
L31/2x31/2x7/16 | 9.8 | 2.87 | 3.26 | 1.04 | 3.26 | 1.04 |
L31/2x31/2x3/8 | 8.5 | 2.48 | 2.87 | 1.01 | 2.87 | 1.01 |
L31/2x31/2x5/16 | 7.2 | 2.09 | 2.45 | 0.99 | 2.45 | 0.99 |
L31/2x31/2x1/4 | 5.8 | 1.69 | 2.01 | 0.968 | 2.01 | 0.968 |
L3x3x1/2 | 9.4 | 2.75 | 2.22 | 0.932 | 2.22 | 0.932 |
L3x3x7/16 | 8.3 | 2.43 | 1.99 | 0.91 | 1.99 | 0.91 |
L3x3x3/8 | 7.2 | 2.11 | 1.76 | 0.888 | 1.76 | 0.888 |
L3x3x5/16 | 6.1 | 1.78 | 1.51 | 0.865 | 1.51 | 0.865 |
L3x3x1/4 | 4.9 | 1.44 | 1.24 | 0.842 | 1.24 | 0.842 |
L3x3x3/16 | 3.71 | 1.09 | 0.962 | 0.82 | 0.962 | 0.82 |
L21/2x21/2x1/2 | 7.7 | 2.25 | 1.23 | 0.806 | 1.23 | 0.806 |
L21/2x21/2x3/8 | 5.9 | 1.73 | 0.984 | 0.762 | 0.984 | 0.762 |
L21/2x21/2x5/16 | 5 | 1.46 | 0.849 | 0.74 | 0.849 | 0.74 |
L21/2x21/2x1/4 | 4.1 | 1.19 | 0.703 | 0.717 | 0.703 | 0.717 |
L21/2x21/2x3/16 | 3.07 | 0.902 | 0.547 | 0.694 | 0.547 | 0.694 |
L2x2x3/8 | 4.7 | 1.36 | 0.479 | 0.636 | 0.479 | 0.636 |
L2x2x5/16 | 3.92 | 1.15 | 0.416 | 0.614 | 0.416 | 0.614 |
L2x2x1/4 | 3.19 | 0.938 | 0.348 | 0.592 | 0.348 | 0.592 |
L2x2x3/16 | 2.44 | 0.715 | 0.272 | 0.569 | 0.272 | 0.569 |
L2x2x1/8 | 1.65 | 0.484 | 0.19 | 0.546 | 0.19 | 0.546 |
L9x4x5/8 | 26.3 | 7.73 | 64.9 | 3.36 | 8.32 | 0.858 |
L9x4x9/16 | 23.8 | 7 | 59.1 | 3.33 | 7.63 | 0.834 |
L9x4x1/2 | 21.3 | 6.25 | 53.2 | 3.31 | 6.92 | 0.81 |
L8x6x1 | 44.2 | 13 | 80.8 | 2.65 | 38.8 | 1.65 |
L8x6x7/8 | 39.1 | 11.5 | 72.3 | 2.61 | 34.9 | 1.61 |
L8x6x3/4 | 33.8 | 9.94 | 63.4 | 2.56 | 30.7 | 1.56 |
L8x6x5/8 | 28.5 | 8.36 | 54.1 | 2.52 | 26.3 | 1.52 |
L8x6x9/16 | 25.7 | 7.56 | 49.3 | 2.5 | 24 | 1.5 |
L8x6x1/2 | 23 | 6.75 | 44.3 | 2.47 | 21.7 | 1.47 |
L8x6x7/16 | 20.2 | 5.93 | 39.2 | 2.45 | 19.3 | 1.45 |
L8x4x1 | 37.4 | 11 | 69.6 | 3.05 | 11.6 | 1.05 |
L8x4x3/4 | 28.7 | 8.44 | 54.9 | 2.95 | 9.36 | 0.953 |
L8x4x9/16 | 21.9 | 6.43 | 42.8 | 2.88 | 7.43 | 0.882 |
L8x4x1/2 | 19.6 | 5.75 | 38.5 | 2.86 | 6.74 | 0.859 |
