Beam Deflection, Shear and Stress Calculator and Formulas for a Beam supported One End Cantilevered with Reversed Tapered Load
Beam Deflection, Shear and Stress Equations and Calculator for a Beam supported One End, Pin Opposite End and Triangular Distributed Load
Beam Bending Moments Equation
Beam Stress Maximum
W = | Beam Load, Total | lbf | (N) |
w = | Beam Unit Load | lbs/in | (N/mm) |
a, b, c, d, x, L = | Some distance as indicated | inches | (mm) |
n = | Distance neutral axis | inches | (mm) |
Vmax = | Beam Shear Load | lbf | (N) |
Mmax = | Moment | lbs-in | (N-mm) |
θmax = | Slope Angle | degree | (radian) |
σmax = | Beam Stress max. | psi | (N/mm2) |
- Boeing Design Manual, Rev G. 1994 BDM
- Beam Deflection Equations / Calculator Supported on Both Ends Uniform Loading
- Beam Deflection Equations / Calculator Supported on Both Ends Single Load at Center
- Beam Deflection Equations / Calculator Supported on Both Ends Loaded at any Location
- Beam Deflection Equations / Calculator Free and Guided on One End, Rigid one End With Uniform Load
- Beam Deflection Equations / Calculator Supported on Both Ends With Overhanging Supports of equal Length and Equal Loads
- Beam Deflection Equations / Calculator Supported on Both Ends Loaded Two equal Loads
- Beam Deflection Equations / Calculator with Ends Overhanging Supports and a Two Equal Loads applied at Symmetrical Locations
